w56 vs g52
Old Dec 6, 2008 | 07:14 PM
91Toyota's Avatar
w56 vs g52
Which do I go with? I've heard you can put a w56 behind a sbc 350...so it much be pretty strong. Don't care about the shifter locations as I'll have to modify the floor anyway. Which one do I choose? Is one better than the other?
Thanks guys. I searched (I know...rare!) for a tranny comparison thread but came up with a page and a half of nothing.
Old Dec 6, 2008 | 08:52 PM
dropzone's Avatar
Fossilized
http://www.4x4wire.com/toyota/faq/parts/
from what I remember the W56 is a stronger case than a G52.
both are dimensionally the same
Old Dec 6, 2008 | 09:14 PM
scuba's Avatar
r151 FTW !!!!
Old Dec 6, 2008 | 09:19 PM
85toy's Avatar
dana 60
Old Dec 6, 2008 | 09:34 PM
scuba's Avatar
Originally Posted by 85toy
dana 60
That wasn't an option home boy
Old Dec 6, 2008 | 09:36 PM
91Toyota's Avatar
dana 60
Crayons
Old Dec 6, 2008 | 09:39 PM
91Toyota's Avatar
so basically it doesn't matter?
abecedarian's Avatar
have fun
http://www.northwestoffroad.com/part...eadapters.html
stagger_lee's Avatar
W56 can handle a little over 200hp as oppose to the G rated at about 140hp tops. I was talking about this last week with another 84 runner owner that swapped in a W56. I read the same elsewhere through a tranny site awhile back.
Old Dec 6, 2008 | 09:45 PM
scuba's Avatar
BOB SAGET @$!@!!
Old Dec 6, 2008 | 09:49 PM
91Toyota's Avatar
Originally Posted by abecedarian
I'm NOT planning on putting a SBC in front of the tranny. All I wanted to know is if I spend $50 on a W56 instead of a G52 then maybe later on it might be worth it since I could run into problems with a weaker tranny.
Definitely sounds like the w56 is the better tranny! Thanks
Old Dec 6, 2008 | 10:21 PM
Spend the $50 for sure. Internals a bit more stout, from the factory. I would look to make sure it has the top shift t-case though (85-88) as opposed to the forward shift. Be easier to run duals later if you choose.
Old Dec 7, 2008 | 12:04 PM
85toy's Avatar
neither was r151
Old Dec 7, 2008 | 01:31 PM
At least he was still talking trannys.
Old Dec 7, 2008 | 01:38 PM
scuba's Avatar
hah, And the r151 is stronger then both of those trannys, Thus why i mentioned it...
But whatev
Old Dec 7, 2008 | 01:41 PM
I thought it was a good suggestion.
Old Dec 7, 2008 | 01:57 PM
85toy's Avatar
lighten up geeze, i was picking on scuba because he posted somethiing that was not(to my knoledge) an option for the OP, also its something ppl say over on pirate, guess ill just go hang out over there.:'(
Old Dec 7, 2008 | 01:59 PM
85toy's Avatar
oh and i change my original post to rockwells. hah
Old Dec 7, 2008 | 04:01 PM
scuba's Avatar
Thank you...
I think if you went that route, all you would need would be a bell housing, and an input + output shaft..If you wanted to use your original transfer case..
But thats something someone else will have to figure out..Cause Idk the specifics...
Old Dec 7, 2008 | 04:07 PM
Well now you're talkin.
