w56 vs g52
w56 vs g52
Which do I go with? I've heard you can put a w56 behind a sbc 350...so it much be pretty strong. Don't care about the shifter locations as I'll have to modify the floor anyway. Which one do I choose? Is one better than the other?
Thanks guys. I searched (I know...rare!) for a tranny comparison thread but came up with a page and a half of nothing.
http://www.4x4wire.com/toyota/faq/parts/
from what I remember the W56 is a stronger case than a G52.
both are dimensionally the same
W56 can handle a little over 200hp as oppose to the G rated at about 140hp tops. I was talking about this last week with another 84 runner owner that swapped in a W56. I read the same elsewhere through a tranny site awhile back.
Definitely sounds like the w56 is the better tranny! Thanks
Spend the $50 for sure. Internals a bit more stout, from the factory. I would look to make sure it has the top shift t-case though (85-88) as opposed to the forward shift. Be easier to run duals later if you choose.
lighten up geeze, i was picking on scuba because he posted somethiing that was not(to my knoledge) an option for the OP, also its something ppl say over on pirate, guess ill just go hang out over there.:'(
Thank you...
I think if you went that route, all you would need would be a bell housing, and an input + output shaft..If you wanted to use your original transfer case..
But thats something someone else will have to figure out..Cause Idk the specifics...
Crayons
