'86 4x4 getting hot
Old Dec 4, 2008 | 07:04 AM
Matfrew's Avatar
Talking '86 4x4 getting hot
Hello YT,
I have an '86 4x4 that is running hot at freeway speed. It cools down at lower rpm, but starts getting hot at 65+. I changed the thermostat and fluid, the fan clutch seems to be operating at idle, radiator has only 20k on it and timing is set at 0 degrees. Any help would be greatly appreciated. Thank you!
Old Dec 4, 2008 | 07:16 AM
ScottyC's Avatar
Originally Posted by Matfrew
Hello YT,
Uh, timing should NOT be at 0 degrees.
Is it a 22RE? If so, the timing should be set at 5* with the E1 and T connectors grounded (on later year models), or the test connector ground on the DS inner fender.
0 degrees means you are running extremely retarded on the timing. I bet you have no power, and running really rich.
BTW, if you don't know how to ground the test connector, then set the timing at between 12* and 16* without the connector jumped.
Old Dec 4, 2008 | 07:25 AM
Matfrew's Avatar
Thank's Scotty,
It's a 1986 CA carbureted model 22r. The timing was set according to the emissions sticker under the hood. Timing has been set that way for a couple years with no power loss and no heating up issues until recently.
Old Dec 4, 2008 | 08:02 AM
newbie93pickup's Avatar
possible your water pumps impeller is getiing worn down. and not pushing as much fluid as is needed at higher RPM's. had a ford do that once. turned out the impeller had been all but stripped clean on the fins that push the fluid.
Old Dec 5, 2008 | 01:02 PM
Matfrew's Avatar
Thanks To All! My Toy Is Shredding The Highway At 80+ And Running Cool As Ice!
Old Dec 5, 2008 | 02:51 PM
abecedarian's Avatar
what'd you find was wrong?
the1998sr5
15
Jul 14, 2020 08:35 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
the1998sr5
Jul 16, 2015 06:20 AM
Poncho0206
Jul 10, 2015 06:21 PM
HRDC0R19
Jul 5, 2015 06:43 PM
