Soft clutch pedal
Old Nov 30, 2008 | 09:44 AM
Tubbyfatty's Avatar
Soft clutch pedal
So i was thinking its time to bleed my clutch, its been gettign kinda soft lately, there is plenty of fluid in the tank. So in this repair manual i bought at an auto parts store it says, turn the bleeder screw under the truck half a turn and have someone depress the pedal quickly, then tighten it back up, repeat if needed.
Does that sound like the best way to do it? Should i just bleed it like im bleeding brakes (pump, hold, bleed, repeat)?
Old Nov 30, 2008 | 11:08 AM
scuba's Avatar
Many people have there ways of doing it...
But yes Pump pump pump Hold, Bleed, tighten. Release pedal, pump pump pump...
You get the picture
Old Nov 30, 2008 | 12:48 PM
LTrunner's Avatar
yeah bleed it like u would bleed brakes...if it dosen't get better after bleeding, it could be the master or slave.they can go bad without leaking...if u fix those and still too soft then it's time for a new clucth...you are better off replaceing thr master and slave if bleeding dosen't fix it cause it's cheaper and easier than doing a clucth, but they may not be the problem
Old Nov 30, 2008 | 02:57 PM
regularjoe's Avatar
I had the same problem it ended up being the slave cylinder. Like everyone else said bleed it like brakes.
Old Nov 30, 2008 | 03:08 PM
DeathCougar's Avatar
the clutch doesn't just "get soft"
You need to locate the problem and fix it, before just bleeding the brakes.
Old Nov 30, 2008 | 04:47 PM
Tubbyfatty's Avatar
It has always been "soft" but i guess its just how toyotas are, I drive alot of manual cars on a daily basis (i detail cars) so every clutch is different.
I did bleed it today and there was just a bunch of air in the line, alot of air bubbles came out the tube in to the clear container full of brake fluid.
Old Nov 30, 2008 | 04:55 PM
abecedarian's Avatar
DC is correct when saying the clutch doesn't just "get soft".... which is why he said to find the problem. If nothing is wrong, the clutch should not be 'soft'.
If you bled it and found air in the system... there is a reason, rather cause, for the air to be in there.... which is what DC was saying.
93toyoguy
3.4 Swaps
10
Sep 18, 2015 04:16 PM
Hugh_Mann
Sep 16, 2015 03:59 AM
Patrick1976
Sep 15, 2015 11:33 PM
Squigglez
Sep 4, 2015 07:33 AM
