Uh oh....
Old Dec 5, 2008 | 09:25 AM
874runnersr5's Avatar
Uh oh....
K, so im starting to do my timing chian because it needed to be done... so the last couple days ive been getting this antifreeze leak from up front, only after i drove... never overheated. So today i started to work on my truck, and i took off the oil cap and it had a bit of foam under it!!!!! my question is, is my truck screwed? or am i safe that i caught it just in time?? i got a new cover and everything so i wont be using the old one.. im just worried some is going ot be messed up now since im guessing it leaked a bit of antifreeze int o the oil..
Old Dec 5, 2008 | 10:03 AM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Drain the oil, check it. Maybe you caught it early. I don't know much 'bout the 22re motors, sorry
Old Dec 5, 2008 | 10:19 AM
yeah, well what damange could i have done driving with a bit of foamy oil?
it drove normal last night
Old Dec 5, 2008 | 10:31 AM
newbie93pickup's Avatar
drain the oil and see how much coolant is in it. if its not that much then you might be ok. pull your valve cover and look for coolant on top of the head could give you an indication of how much collant got in. may have to do a couple oil changes to get it all cleaned out so i would start with some cheap dino oil first and maybe something that will help take the moisture out of the system. the only way to know if you hurt anything is to drive it and pay close attention listen for anything new pull your rocker arm cover and look for coolant on top of the head around the valves.
Old Dec 5, 2008 | 10:51 AM
DeathCougar's Avatar
As long as you didn't overheat it, and your engine wasn't knocking, you are fine. You caught it early. Get a new timing cover, change the oil a few times, and next time when the front of your engine sounds like a can of spoons, fix it. Don't let it get this bad.
Old Dec 5, 2008 | 12:01 PM
woohoo, drained the oil and everything was good!
no milkyness of the oil or anything.. so i guess im really lucky.. not to get the stupid pulley bolt loosened...
Old Dec 5, 2008 | 12:03 PM
yeah DC, its hard being a teenager and working fulltime..
i guess i shoulda done it earlier thoe.
Old Dec 5, 2008 | 06:07 PM
Just a little update, removed the valve cover(thoese washer's are a pain to get off) and opened er up and no foam, well there was a tiny bit at the very back on the rocker thing but thats all i could find. Anywho, my drivers side guide mustve went for a trip in my oil pan...
Old Dec 5, 2008 | 06:46 PM
abecedarian's Avatar
valve cover seals are easy- wrap some duct tape or electrical tape around some channel-lock pliers and work it.
so, now what?
Old Dec 5, 2008 | 06:51 PM
bigt's Avatar
fix that yoter!
Old Dec 5, 2008 | 08:09 PM
oh trust me shes being fixed!!
now, i just need to find a way to drop my pan.. waiting for my friend to come and lend me a hand to so yeah. After i figure out how to drop the front diff then il set up tdc and remove the cover.. werid thing was i couldnt find any gold links in the chain.....
Old Dec 5, 2008 | 08:12 PM
just a pic for you guys!
Old Dec 5, 2008 | 08:16 PM
toyota4x4907's Avatar
Did it look like this?--
Old Dec 5, 2008 | 08:17 PM
yup, not as bad thoe.
Old Dec 5, 2008 | 08:19 PM
hm. Im gunna change the oil tomorrow. Im hoping there isn't any antifreeze in the oil.
Old Dec 5, 2008 | 08:22 PM
crappy man, im so lucky i caught it befor it got worse.... i fell stupid doing my timing chain now seeing how easy it is. Im just hoping that it doesnt foam after i do everything
Old Dec 5, 2008 | 08:29 PM
mine already had metal guides when I bought it at 87K miles...So I dont think my t-chain is rubbing the cover. Abe has mentioned that its possible the Intake manifold gasket is leaking, or the IAC valve.
didn't mean to hijack
So you already have the t-chain changed? or you're doing it right now?
Old Dec 5, 2008 | 08:31 PM
oh lucky!!
doing it right now, taking the odd breaks. not to much of a rush just need to get it done by monday so i can drive to work. Im just taking my time and seeing how everything works... its my first time into this engine and yeah. One thing that concerns me is that one of the bolts from the P/O mustve broke while doing something with the water pump or timing chain cover.. so now im stuck with one less bolt.. what do i do now?
Old Dec 5, 2008 | 08:35 PM
hm werid, found this thread with the same problem as me, but he broke 3 and the dealership gave him studs instead of bolts.. i wonder witch type of bolt/stud broke off mine...
Yeah, thats understandable! I would be taking my time too, and checking everything out Its fun to do!.
bolt: Get a new one from like Ace Hardware or Lowes or somewhere like that maybe.
You should take a lot of pics with the cover off. I want to see what it all looks like.
