Replacing Ignition Coil
Old Nov 28, 2008 | 10:58 PM
myyota's Avatar
On a stock coil the FSM says the primary rating should be between 0.5 - 0.7, what if you replace the coil with one that has a 1.4 primary rating ?, will this affect or hurt anything ?. This is on an 86 4Runner with a 22RE.
Old Nov 29, 2008 | 02:57 AM
Bigblock's Avatar
Good question.My only concern would be the ignitor.Can it handle the extra resistance?Got a spare?Try it.
Bigblock
Old Nov 29, 2008 | 09:09 AM
iamsuperbleeder's Avatar
what coil are you wanting to put in it?
I put an MSD on my stock igniter about a week after I got the truck and have had absolutely no problems; now I don't know what the resistance is on that coil is either, but I'm just say'n if that's what you've got you shouldn't have any problems; at least I don't... but I do have a spare igniter and OEM coil just in case
Old Nov 29, 2008 | 12:07 PM
abecedarian's Avatar
generally, you shouldn't have a problem. the biggest issue you might face is a high-speed misfire. the higher resitance coil may take slightly longer to reach saturation and may not be able to develop the highest possible output to the plugs.
smthwsn357
May 1, 2024 07:28 AM
sandyota
Feb 4, 2021 11:16 AM
Sleaker
Aug 26, 2020 06:03 AM
mlavery85
Jul 12, 2015 10:33 AM
Vargntucson
Jul 4, 2015 12:15 PM
