tranny problem...
Old Dec 5, 2008 | 12:05 AM
paul86yota's Avatar
tranny problem...
I have an '86 4-wheel drive 5-speed yota, I went out this morning and warmed the truck up and drove to my friends house to take her to work, it drove fine till I got there, when I backed up to turn around I put it in 1st gear and eased out on the clutch pedal and the shifter popped out of gear. I put it back in gear and held it and drove on no other problems. Got her to work and it did it again, same thing. When I got home I parked the truck and figured I'd try 1st again, it popped out again but wouldn't go back into gear it just grinded and wouldn't go in gear, so I put it in second and it worked fine. Could it be something simple like changing the fluid in the hydrolic clutch or is my tranny about to drop? Thanx in advance for any help!
Old Dec 5, 2008 | 12:29 AM
85TurboRunner's Avatar
Sounds like the 1st gear syncro's going out. How many miles on the tranny?
Old Dec 5, 2008 | 08:31 PM
paul86yota's Avatar
tranny problem...
original engine and tranny @ 140k, is it my syncro, and how hard would that be to do myself without any transmission experiance except changing fluid and filter in a chevette
Old Dec 5, 2008 | 08:56 PM
abecedarian's Avatar
it's not 'that' hard, but everything in a transmission moves.
if you're going to be delving into it to replace synchonizers, you might as well rebuild the entire thing. If you don't have the tools in your box already, get someone else to do it.
Old Dec 5, 2008 | 09:32 PM
paul86yota's Avatar
well it would be alot easier if I had a diagram of some sort to look at and see what im getting into, anybody got a link or a pic of the tranny so I can see what it looks like? thanx
ladybugRC
458
Aug 21, 2020 10:41 AM
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
Davebarbier
Nov 3, 2015 03:28 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
