tailgate window motor
Old Dec 4, 2008 | 06:52 PM
orbital02's Avatar
Hey guys, my tailgate window motor finally died the other day. I ordered a used motor from Collier's successor, Jenny. I hooked it up and nothing happened. Just so everyone is aware, I already had my window motor wired directly to my own toggle marine switch earlier this year because the window started to "act up". Now I don't know what is wrong. I have tested both motors (when out of the truck) and the original while still in the truck by hooking the motor directly to a battery. I know this procedure should work since I have done this before, but neither motor will do anything. Its getting pretty darn cold here in Indiana so any help would be appreciated.
Old Dec 4, 2008 | 07:29 PM
fireman1559's Avatar
maybe the used motor that you got is bad?
Old Dec 4, 2008 | 09:02 PM
bigt's Avatar
fried motors both of them.. you can also use one from a drivers 4 door runner!
Old Dec 5, 2008 | 05:03 AM
orbital02's Avatar
Will the mounting bolts line up correctly if its from the driver side door?
Old Dec 5, 2008 | 05:08 AM
bigt's Avatar
from a 4 door iknow they do i used one in my runner for sure!
Old Dec 5, 2008 | 05:27 AM
waskillywabbit's Avatar
Call Deathcougar at nix99. Just got a motor and regulator from him, worked flawlessly. He knows a lot about old Toyotas. But speak to him, not someone else.
Old Dec 5, 2008 | 07:50 AM
mental's Avatar
I did this yesterday. Drive gear on the old unit was chewed up, pulled the driver's side window motor - direct bolt in, although it looks like the poles are reversed between the two versions. I may have the plug out by 180 degrees, but to go up, I use the down switch and vice versa. Easy fix either way and my window is once again moving.
Old Dec 5, 2008 | 03:39 PM
orbital02's Avatar
Thx for the help guys. I got it to work.
okamikai
Apr 30, 2018 10:19 PM
Lochsa
Aug 2, 2015 02:51 PM
britishdudes2dr
Jul 25, 2015 06:47 AM
94yotaky
Jul 23, 2015 07:50 AM
lfcarrion3
Jul 18, 2015 04:05 PM
