neutral clutch switch
Old Dec 4, 2008 | 06:05 AM
jms3251's Avatar
yes i was wondering if the neutral clutch switch and the slutch start cancel switch are the same thing and if not where is the neutral clutch switch located. application is a 93 pickup 4x4 regular cab 22re
Old Dec 4, 2008 | 12:25 PM
eric-the-red's Avatar
No they are not the same. The neutral clutch switch should be on the clutch pedal, up near the firewall.
Old Dec 4, 2008 | 01:16 PM
annoyingrob's Avatar
The neutral clutch switch only allows the motor to start when the clutch is pressed down. The clutch bypass switch allows you to bypass this, and start the vehicle with the clutch up.
ViperTT
Aug 14, 2015 05:27 AM
KBar
Aug 3, 2015 05:14 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
PlayAwhile
Jul 20, 2015 11:36 AM
colinmil
Jul 6, 2015 04:03 PM
