86 4runner trans swap no start now
Old Jul 27, 2015 | 08:36 AM
KBar's Avatar
Just finished my 5spd swap and timing chain replacement yesterday truck cranks but won't start. Bypassed neutral safety switch, put dizzy bolt back exactly where it was before I took it off. Am I missing something? It tries to start, I let off key than dies. Ideas?
Old Jul 27, 2015 | 02:13 PM
wyoming9's Avatar
Red face
Timing 180 Degrees off??
All the plug wires on correct and pushed down .
same with the coil wire.
get the ECU ground hooked up and getting a good ground??
Did not disconnect the negative battery cable and caused some fuses to open??
Your not trying to start it with the air
intake hose off??
just ran out of gas ??
It has happened enough to drive you crazy.
A couple of things to think about
Old Jul 29, 2015 | 02:59 PM
Countryfried's Avatar
Definitely sounds like your timing marks may be off a bit, most common problem after a Tbelt job. How was it running before the Tbelt replacement?
Old Jul 30, 2015 | 06:50 AM
KBar's Avatar
Dizzy was off a few teeth
Old Jul 30, 2015 | 12:41 PM
RAD4Runner's Avatar
Originally Posted by KBar
... truck cranks but won't start. Bypassed neutral safety switch,
If truck cranks, then there is no problem with the neutral safety switch.
So did you fix it?
Old Aug 3, 2015 | 05:14 PM
KBar's Avatar
Yup runs like a champ, but now I want to buy a new tacoma
JF9243176
Oct 8, 2017 04:21 AM
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
vasinvictor
Jan 20, 2016 12:39 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
duckhead
3.4 Swaps
7
Jun 18, 2015 06:54 AM
