94 pick up....
Old Dec 4, 2008 | 08:30 PM
elnino's Avatar
94 pick up....
well is giving a lot of problems....
we went wheeling...truck got stuck...in deep deep mud...then it wouldnt start....so we pushed all the way out...then pull it and started by kicking the clutch...it started..drove it home....
got home..washed the engine,changed the oil...started and run perfect....next day....turn it on...and is misfiring like crazy,it takes a lot of time to start......so we changed the rotor and cap on the distribuitor...and still...
what can it be?
it has a snorkel...so we know there isnt water in there...
Old Dec 4, 2008 | 08:48 PM
leebee's Avatar
did you actually check the air box? a snorkel does not mean your intake is invulnerable and, that is not the only place moisture can penetrate. dipsticks (oil& trans), fuse boxes, ecu and interior fuse panel to name a few.
check all those as well as your grounds and clean every connector you can find. water, like dust and dirt, will get places you dont want it.
lee
Old Dec 4, 2008 | 08:50 PM
elnino's Avatar
i agree with you...
filter is dry....and was dry....at that momment....
any specific place i should check?
Old Dec 4, 2008 | 09:31 PM
elnino's Avatar
bump
Old Dec 5, 2008 | 09:20 PM
elnino's Avatar
well i changed the cables,and sparkplugs...still misfiring....ecu was dry,not cut cables or anything wrong with it...for the most part water didnt go to that side....so...we are safe there??
any specific vacum line i should check? or sensor?
oh and the cat is not clog because i disconected it from the downpipe and still runs crappy
Old Dec 5, 2008 | 10:31 PM
Matt16's Avatar
Did you get the moisture out of the dist cap? WD40, Fluid Film or Chuck Norris tears would work.
choppe777
May 16, 2016 08:00 AM
longbed
Sep 16, 2015 10:35 AM
LotOMiles
Sep 14, 2015 11:45 PM
mirabile4runner
Sep 3, 2015 07:15 AM
