how do you Tell if the m.a.f is bad
Old Dec 4, 2008 | 06:01 PM
galloway's Avatar
ok i have a 3.0 v6 my truck is having problems starting. it will get close but it wont stay running for longer than 10 seconds. i put my hand over it and it helped it alittle. than we just took the hole thing off and it it was the same as befor. so does this sound like it may be the maf thanks
Old Dec 4, 2008 | 06:18 PM
874runnersr5's Avatar
you can try testing it, 4crawler has info on it.
http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
Old Dec 4, 2008 | 06:36 PM
Jay351's Avatar
You break out the ohm meter and test it!
Old Dec 4, 2008 | 06:40 PM
galloway's Avatar
cool thanks dude.
Old Dec 4, 2008 | 07:15 PM
scuba's Avatar
AFM What ?
Old Dec 5, 2008 | 12:28 PM
galloway's Avatar
do you think my timing may be off by a tooth. my friends working on it and he said that it ran fine but than he looked at the timing and it was off by one tooth. he fixed it and now its having problems starting back up. if we put our hand over the intake it will almost run. i have grate compression like between 180 190.
Old Dec 5, 2008 | 01:08 PM
Matt16's Avatar
Your MAF is bad if:
it ran away with your sister
it kicked your dog
it stole the walker from an old person
if it defecated on your porch then covers it with flaming newspaper before ringing the bell
if it tapes fire crackers to cats tails
if it cuts the brake cables on wheelchairs.
Old Dec 5, 2008 | 01:59 PM
galloway's Avatar
oh dude that helps alot thanks.
ghostmoney
Jan 28, 2018 11:42 AM
Blamalam
Aug 16, 2015 12:29 PM
corey519
Aug 12, 2015 11:12 AM
nonstop
7
Aug 11, 2015 09:26 AM
keithporter83
Jul 18, 2015 12:37 PM
