- 3vze pinging/knocking? timing issue?
- o2 sensors
- exhaust question
- 22re loss of power, sluggish
- aisin hub turns to lock cv's dont engage
- O2 Sensor 22re vs 22rte
- Leaking TVV valve?
- 22R knocking in the top end type of noise
- Toyota Truck dimmer problem ?
- Help with ground location on 3.0
- 1988 4runner intake tube?
- Code 25 & 26
- Has anyone ever seen this much carbon build up in the intake?
- 3.0 rebuilt engine install questions
- 3.0 "cuts out" for a split second?
- Bumper choices for 88 Pickup?
- 86 22RE spun rod bearing
- 874runner W56 transmission issues
- 22re Overheating really quick
- Idle compensator valve missing on carburetor
- 93 3.0 runs rough, sputters and dies when off gas
- water temp sensor, I found a new one in the garge, should I swap it?
- new 3.0 thermostat, is it the right part # 90916-03079 ???
- '94 Pickup No Power, Terrible MPG
- 89 t4r 22re 5spd...locked up after timing components replacement
- Water temp Sender
- side draft carb on 3vze & 22re
- No Crank, Just Clicks Once, No Brake Lights. Gauges, Wipers (But Headlights Work)
- ROCK hard brakes for a moment
- 4WD troubles
- Failed Emissions High Idle HC
- Rebuild 22RE and piston ring breaks a week later
- Old Carcinoma Reached A Milestone Tonight!
- fuel tank removal
- Weights
- Reverse??
- ENGNBLDR FEK 4 piece front end kit contents
- Oil Pan Removal--What else should I replace?
- 87 4Runner brake lights and skid plate
- How do you set the throttle stop screw on 22RE?
- Blower Fan Switch Repair - A HOW To with Pictures
- 3.0 Head Gasket Replacement Notes
- 2nd Gen Body Lift & Spring Spacer Questions
- Nic's 1986 4Runner Project Thread
- 1991 3.0 V6 Spun Main Bearing
- Water pump gasket question?
- My new Softopper 89 ext Cab
- Cooling system problem
- Doug Thorley header install with automatic trans
- Effects of driving with blown head gasket...
- Rough Start and No Power. Exhausted All Resources
- fluid clutch and cold nights
- 91' PU automatic hard shift
- 22RE Had a bad waterpump, now smokes white only when warm and no cab heat.
- 94 using oil, valves?
- 22re temp gauge not working when t-stat removed
- 22RE Misfire
- Just finished 3VZE head gaskets! 3 Questions...
- 4-5" lift and 31 pics??
- install bypass toggle for blower motor speed control
- Too much drag on the brake disk?
- 22re starting issue intermittantly (clutch/brake switch?)
- Late model Intake, supra afm, and long block
- lift options for '92 pickup
- 22re running issues after rebuild
- cat-back exhaust 91 PU v6
- GForce Chips - Do they work?!?!
- Needs a new head? ( see pic )
- Will a 1994 be go on a 1988 truck
- leaf springs
- Installing new idler arm???
- 5 speed rear seal--part #?---
- Driver side window goes up but not down
- leaking from sunroof switch
- 88 With code 52, possible wrong ECU being used?
- 94 4runner v6 rear fuel leak
- 94 pickup vs 94 4runner - front frame
- Loose Clutch Fork and a blown slave cylinder
- trannys gone!!!!!!
- 3vze 95 4runner labor hours
- Worn rod bearings, or too light weight oil?
- finally got my sr5 gague cluster
- Fuel pump gasket
- 22RE Thrust Washer Problem?
- 88 pickup my rear leaf issues
- Just bled my breaks and put new front pads on and now my trasmmission is acting crazy
- 3VZE 3.0L Heads - Can you measure for previous machining?
- 1 Locker or 2 Limited Slips?
- Frame Rot Repair
- Friendly debate about diff drops
- 3.0 oil leak - below intake in valley
- Extra Fuel Tank
- ever heard of a "custom cab" 87 pickup?
- New Timing Chain install problem help please!
- Question on part condition 4Runner Third
- headgasket change 22re, can't get coolant pipe off!!
- 1995 3VZE Fuel Pump
- Hesitation under load, and other things
- 22re cuts out only when crawling up steep hills??
- best tune up ever
- Clutch related issue?
- Tech help needed on 94' 22RE!
- 22re won't stay at normal operating temp.
- 1994 22re 2wd pickup with violent start and no-load misfiring
- A lot of BHG questions, please no 3.4/3.0 debates... long post
- Can't get the 3vze to run after installing long block
- Thorley Header - "Does not fit with hydraulic clutch"
- proper vafm swap for the 3vze
- Brake bleeding - Drips out of bleeders
- Post headgasket job
- My mystery oil leak (pic inside)
- using excessive fuel and knocking
- Aftermarket Stereo Install, No No HVAC Lighting, Where'd I Go Wrong
- Lacking power going up hill
- 3.0 head bolts/arp studs
- the lux has died :(
- 93' 22RE died, now won't start.
- 89 4runner,22re, AC pulley and PS pulley the same?
- 1989 4runner door panels
- 94 4runner v6 fuel leak
- Retrofit Tach Wiring Help
- Engine stutters when headlights come on
- Why are people so stupid? (Accident Pictures)
- Mystery box
- 4runner will not go over 55 MPH
- 22re stalling issues?
- Why cant I find headers? (3VZE)
- Water in Oil
- 3VZE 3.0L Head Bolts - TTY or not, source/ brand
- 3VZ eating oil.
- 1995 4Runner 3-VZE Valve Cover Leaks - Gasket Advice?
- Headlight Upgrade
- Fronts lock up with hubs engaged
- help identifying this harness plug
- Heater Control Cable
- Mustang Seats in 93 Pick-Up
- r151f bell housings question
- Temp Sensors
- front differential
- Well, where do I go now? crushed pilot bearing
- Bought a 4runner! Need some brake line help
- IFS brake upgrade
- '86 22re Purrfect cold start, rough almost bucking warm start
- 89's running propane
- 87 turbo 4runner
- bad gas! and alot of drag at freeway speeds
- '93 Pickup starting problems
- More than one steering box ratio?
- Crash in 91PU: What now?
- what am i missing on my 22RTE? Pics inside
- IAC Valve????
- 3vz not even trying :(
- Just replace cv axle, brake caliper bolt noise?
- I need fuel!
- Blower fan question
- 20 yr FRONT END refresh.. what am I missing?
- slack in rear diff?
- Help with codes/rough idle: 86 4runner
- Need engine help
- wont start 89runner
- Cold air intake mod - new metallic noise?
- R151F swap into AT 4Runner
- 140 Amp Alternator
- Driveshaft questions...
- 91 4runner radiator fit a 94 toyota pickup?
- 1991 toyota truck sputters under load BAD
- Heater Valve Cable Question
- 92 Toyota died on the road now wont start!!!
- 1992 22re Removal/Install with pics
- Removal of Lock for Rear Window Switch
- 88 4runner 4wd light not working?
- Need help with my heads!!
- Gunk in plenum
- Light sputtering in 91 4 runner
- very high idle on 93 4runner 3.0
- Coolant passages/ Vacuum hose replacement?
- a nice and cleaned intake (before and after)
- 22RE pickup starts then dies
- 86 4runner starter help
- Cabin Light - Sensor?
- Fuel Smell in Cabin (again)
- 86 4runner Auto Trans Starter question
- 3vze feeling underpowered
- 1st / 2nd generation Toyota Truck Maintenance schedule (Excel file)
- 22re rebuild: ZERO valve clearance
- Throttle cable???
- Aisin manual hub won't fully engage/just how bad is 2wd in the snow?
- 89 gauge cluster swap question.
- Transmission swap problems 1990 4runner autu to mannual
- How to install a 2.4 turbo on a 2.8 hilux.
- stupid question about cranking t bars bars vs bj spacers
- Is this a blown head gasket?
- HID Projector Headlight?
- 3VZ-FE Factory Service Manual
- water leak in cab...
- 2nd/3rd gen COR compatibility
- New yota owner
- Toyota Logo,... no more silver.
- Cleaning out the Holes
- 3vze Manual Transmission Question
- HELP stripped hub bolt
- 3VZE 1/8" Ball bearings Found behind Timing Cover
- How Critical is 180* when installing head bolts?
- Crane ignition kit
- Weird tire wear-not sure what it is
- No 4WD Light
- VAFM passes all tests still throughs 24 & 31 codes
- exhaust leak near engine?
- High mileage and with a turbo
- What year is my engine?!?
- cabin water leak? near driver side kick panel
- 86-95 has an AFM not MAF!! Interior pics and explanation
- another tps adjustment question
- Autozone Duralast transfer case mount or OEM?
- 89 auotomatic
- 1991 fan shroud for 1990 4runner
- Would a cylinder full of antifreeze cause my starter to grind?
- Project: Boosted Brown
- 95 Runner lost power
- A.D.D. relay/fuse location question
- Where to buy a flat bed
- 87 pickup transmission problem!!!
- Engine Heaters..... What do you think?
- 86 toyota pickup runs barely
- 94' 4runner Terrible jerking shudder on takeoff
- Cleaning oil galleys on 3.0 rebuild
- Infamous 3VZE J-Tube leak again... Few questions
- 1987 4runner Bed Ideas?
- 3vze tranny throttle cable stuck
- Checking transmission fluid level
- Intermittent starting. Need advice
- Looking for a Softer Rear Suspension
- 22RE California smog legal header??
- Pcv and valve cover filter
- What am i looking at here?
- am I following the troubleshooting guide correctly?
- 4wd blinking 3 times then light goes off.
- Adjust injector pump ? Hilux 2.8 93
- What is causing this buildup on my spark plugs?
- Carburetor Rebuild Time
- Trouble Starting After 3VZE HG Repair
- failed the idle test at inspection (question)
- Temperature Switch/Gauge
- Starter help
- 93 22 re question
- Toyota 5 speed tranny help!!
- sway a way torsion bars or bj spacers?
- Fresh rebuilt 22-re idle surge
- Speed sensor (1994 toyota pickup 4x4 22re)
- acceleration problem
