HELP stripped hub bolt
Old Dec 24, 2010 | 11:14 AM
92yotahale's Avatar
I just bought new warn hubs for my 92 toyota. I took the 6 bolts off the hubs i have now and i took off the 6 acorn bolts and removed the cover to the hubs. i tried to loosen the bolt thats in the center of the hub and it just kept spinning so i put the truck in 4 wheel and the bolt stopped spinning. i went to loosen the bolt that holds the hub in and it was already stripped. what should i do now? please help
Old Dec 24, 2010 | 11:29 AM
waskillywabbit's Avatar
What? Which bolt are you talking about? Take a picture.
WARNS suck compared to the OEM Aisins.
:wabbit2:
Old Dec 24, 2010 | 11:46 AM
92yotahale's Avatar
when you take the cap off the aisins theres a bolt in the center that you have to take off to get the hub off its a 12mm and it has a washer behind it
Old Dec 24, 2010 | 11:48 AM
The "gold" bolt/washer that is in the end of the axle?
The axle hole has stripped threads or the bolt has boogered up threads? You can drill and tap the hole or clean up the threads with a bottom tap and buy a new bolt.
:wabbit2:
Old Dec 24, 2010 | 11:49 AM
2DoorRunner's Avatar
Stripped as in rounded off? Try visegrips?
Old Dec 24, 2010 | 12:04 PM
92yotahale's Avatar
yes stripped as in rounded off. i cant get vise grips in there to loosen the bolt it sits in about an inch and a half..the bolt has stripped theads i cant turn it anymore
Old Dec 24, 2010 | 12:06 PM
Hammer a smaller socket on it and hit it with an impact.
Or try to bolt out sockets.
Shouldn't be too bad.
:wabbit2:
Old Dec 24, 2010 | 12:08 PM
92yotahale's Avatar
the bolt doesnt look too bad..after i get the bolt off i should just be able to take the old hub right off and put the new one right on?
Old Dec 24, 2010 | 12:09 PM
Yeppers.
:wabbit2:
Old Dec 24, 2010 | 12:13 PM
MudHippy's Avatar
Bolt Extractors
  • When you are faced with a rounded-off, rusted-tight or painted-over bolt, bolt extractors will break it free
  • Reverse spiral flutes are designed to bite down to provide maximum gripping power
  • High carbon steel ensures longer life and greater durability
  • Universal lobular design fits all types of fasteners
  • 3/8" square drive for use with hand ratchets, impact wrenches, and air ratchets; hexagonal flats for use with flat wrench, pliers, adjustable wrench, sockets or VISE-GRIP locking pliers
Product Specifications
DRIVE 3/8"
CARTON QTY 1
REMOVES FRACTIONAL SIZE BOLTS 5/16"
REMOVES METRIC SIZE BOLTS 8mm
http://www.globalindustrial.com/p/to...rs-irwin-53902
Old Dec 24, 2010 | 12:17 PM
92yotahale's Avatar
ok thanks..also do i need that gear thats behind it? does it fit right into the new hub
Old Dec 24, 2010 | 12:33 PM
MudHippy's Avatar
I'm not sure exactly what you mean. But, I'm pretty sure the answer is no.
There aren't any parts that are seperate from the hub locker body behind that bolt. The body comes off as one piece. Your new hub locker bodies should have all the required components. Nothing gets re-used, except the nuts/bolts/washers. AFAIK.
carlspeed
Aug 23, 2015 02:59 PM
upongame619
Aug 1, 2015 12:12 AM
pyramid
Jul 30, 2015 10:05 AM
PlayAwhile
Jul 20, 2015 11:36 AM
Steven.m.paulk
Jul 13, 2015 01:40 PM
