- Kick Down Cable Question 93' 3VZE
- Coolant line for 3vze
- Intermittent gas smell 1986 22re
- Torsion Bar Lift
- Engine knocking, shaking, hard to start with video
- 22RE EFI question.
- Need your help
- 22re weak out of idle and at lower RPM's when under load
- should the car move with parking brake on in drive?
- Yet Another “hard to start when warm post” for a 93 22re
- 86 yota pickup AC questions
- Grinding noise in front end
- Free -- two automatic front hubs from '87
- General "Thank You"
- Idle Surge Issue (tried many suggestions on previous threads)
- Can't find a replacement oil cooler line for 1993 auto trans. Any ideas?
- 91 stock steering wheel installment
- 93 5speed 4wd ecu trouble!!
- 94 Yota Wont Start
- 4x4 not engaging! Ideas?
- Persistent TPS Issues (rough idle, stumbles under acceleration)
- 1994 4Runner 3VZE power loss
- Need help with part number for power steering pump reservoir oring
- Charging system questiion(s)…
- Taurus fan blowing backwards
- Knock Wire
- Charge light on and Gauge fuse keeps blowing!
- 22re stumble/jerk under acceleration
- 94 4Runner overheating?
- 1990 toyota wont start unless jumped
- 22R weirdity
- refinishing windshield channel
- '93 pickup rattle when steering right
- Area of the cabin for a truck
- 88’ pickup weird idle vsv?
- 5VZ clutch and flywheel in a 3VZ truck - it works!
- 1993 22re alternator replace
- “What if we just let the kids apply the graphics?”
- Neutral Safety Switch Wiring Pinout?
- Installed new climate control lever assembly.
- 1992 DLX leaking Transmission line.
- Strange O2 behavior
- Front end super bouncy
- Running rough
- Front driveshaft making jingle noise
- 91 pickup rough idle/ stalling
- Fuel delivery issues 94 Pickup 22re Base
- Broken Bump Stop - 91 4Runner
- Dash lights and tail lights wont come on, please help
- shift interlock not depressing on 91 4runner
- Automatic 4x4 shift assymbly
- Recent radiator replacements
- Wiper transmission
- Front Diff (3rd member) question
- Christmas in July
- 87 Yota Engine Install Question
- 87 Yota. Can you identify this bracket?
- vibrating clutch pedal
- Wheel hub question
- Power brake booster pushrod pin gauge
- 230 degree, killed it and blew off bypass hose
- 1986 pick up
- Mysterious oil consumption 95 3.0
- Removing 3.0l without transmission
- '91 4Runner 3.0 Power Steering Gear Box Leak
- Front Diff Ring gear chips. Can I run this?
- 1988 4Runner V6 5spd dying in gear.
- 1987 pickup tonneau cover
- 1986 4runner Seat Belt Hardware
- How high of a flow will a 3.0 take?
- Alternator Repair Questions
- How to remove washer nozzle 86 22R Base pickup
- Temp gauge on digital dash.
- Code 52 1994 4Runner
- 86, 4x4, axle play
- Crank no start
- Help needed: electrical short on an 87 Pickup
- Radio gray ignition always on
- Code 71 EGR
- vapor canister alternative ????
- Troubleshooting a High Idle and Overheating
- New 4runner shocks on a 2nd gen?
- Air Conditioner questions
- What can I expect?
- 1990 PU heater core fix
- front wheel bearing check
- Removing inner knuckle seal
- 4 wheel drive won't engage
- Spark plug ugly
- 22RE compression test: 1 cylinder at 125 PSI
- LED headlight help
- 89 Pickup 22RE compressor photo
- Speedometer Error, 1990 2wd Pickup, Not sure why, Suggestions?
- 92 22re power issue
- 1989 4Runner clutch pedal noise?
- Fuel issue?
- T100 Bed Cap
- Mystery plugs 1995 4Runner 4x4 V6
- Electrical question
- dry cylinder??
- toyota 3.0 with lexus 3.0 heads
- Need complete exhaust system---where to get?
- 22r timing chain
- 89 Toyota AC Harness
- 22re overheating on steep mountain roads
- 1989 compressor manifold
- Lower intake thermostat housing
- 87 22RE - Bad Fuel Pressure Regulator?
- 87 Pickup SR5 Turbo no idle and bogs down when accelerating
- Rear brakes wont bleed,HELP!
- No. 2 Speed Sensor
- 22re catalytic converter
- 4x4labs rear bumper install
- Secure the jack in '89 2 door pickup?
- 3.4 crossover on 3.0?
- 1991 Truck Wheeling the mountains
- bare metal rims
- Aerodynamic Testing and Modification
- Vacuum switching solenoid colors interchangable
- A/C Compressor Bracket
- Tail light fuse
- Instrument Cluster / Dash rebuild 91 4Runner
- Oil pressure sender for 3VZE SR5? Part# needed!
- 22r missing and popping
- attacking rust
- Throttle cable binding
- ignition timing specs.
- 4runner Softtopper on a long bed pickup?
- TPS causing ignition arcing?!
- 3vze hard warm starts?
- 87 Toyota Pickup acceleration issues
- Toyota 2l-t vs borg warner velvet drive
- Refrigerant oil
- 1987 SR5 Turbo pick up
- 1st/2nd gen 4runner rear seat covers
- Power loss under load
- 93 3vze rpm problems
- Timing
- 1st gen 4runner tailgate window
- Troubleshooting first issue with 22RE
- 93 pickup 3vze radiator fan always running
- 1990 4Runner Coolant Pressure/Leak Problem
- T100 booster and MC in 88 V6
- 22RE no fuel after rebuild
- Bleeding with emergency brake engaged
- Engine Issues
- 1st gen 4runner engine swap
- 1991 4runner rear window
- Smittybilt bumpers
- 3VZE - Anyone know Throttle Stop Screw Size
- 1995 Toyota 4Runner V6 3.0 3VZE
- 1990 Lift removal help.
- Help finding part
- From running perfectly to no start 92 22RE
- What should I add to my center console?
- Is This Normal?
- 95 T100 engine hesitation
- Land Cruiser fog light switch...
- Rough/no idle, no power after dead battery need help
- strange tab on rims
- Runs great cold; runs bad warm
- Pickup housing Chevy 63
- 1993 22re pickup cranks but no start
- Help with 3rd temp sensor wiring location for aftermarket gauges (87 22re)
- Changer 6 disc Cassette?
- Soft pedal with line lock
- 3VZE Code 52
- Overhauling 22rte
- No Power Need Help!
- 95 4Runner Losing Power upon Acceleration
- Shot myself in the foot.
- Possible NSS issue?
- Timing chain too tight?
- horrible clicks, vibrations, trans or transfer?
- Hesitant acceleration + code 25 after sustained full throttle
- Transfer case leaks only in 4x4
- Code help needed
- 1988 w/ 22re cranks but wont start after moving the wiring harness, removing heater
- ID these coil springs help.
- Un-Bobbing a 1995 Pick Up
- Soft Topper bikini top?
- seat cushion support rebuild kit, search for
- braking with only one side
- steering wheel / speedometer issue
- rattling driver side window
- 12 Hole Injectors and ECU
- Need speedometer help
- 93 22re starts with starting fluid
- Part difference - 87 RTE 4Runner vs 86 RTE Pickup?
- Idle drops with lights on or fan on
- Posible bent connecting rod?
- Kill Switch button
- 20R steel rockers on 22RE?
- 88' RWD toyota pickup, 22RE (break & battery light on, squealing and no brights)
- Clutch Release Fork Boot
- New speedometer cable making noise
- 22RE Performance alternative
- 88 3vz: no turn signals, no gauges (except speedo), Charge light ON, no tach,
- Bad vibrations at low speeds
- Center console lid restored
- Steering parts replacement
- LC Engineering???
- 22re Compression 215 too high?
- O2 sensor riddle
- 22RE coolant in oil questions.
- cranks, no start, mechanical noise/smell
- What is wrong here?
- 3.0VZE overheating after top end rebuild
- Power Locks Weak on 1986 4Runner
- How much play center support bearing
- Looking to trade my cable driven sr5 cluster for your electronic speedo cluster?
- 1994 4Runner 3VZ-E #3 and #5 Misfire
- 1992 22re truck
- 1994 Toyota 4Runner 4WD Problems
- Dashpot replacement
- NEED a reputable shop in the Pocatello Idaho for my old 85 EFI pickup
- What’s it worth?
- My first 4Runner-Some problems
- 63” swap with VERY little flex
- Ignition Control Module Testing (1992 22RE)
- Does my 3.0 sound like it is ticking unusually loud to you? (Video)
- Sticker ID help on 1986 SR5
- V6 Transmission dipstick length
- Torque
- Mystery dash plug
- Oil blowing out from the top of valve cover 22re
- To Swap or not to swap
- 22re Coolant Leaking From Block?
- 87 22R 2WD Auto question(s) as I near the end of my build
- 1991 V6 progressive power steering antilock brake nightmare
- Reserve gear wear r150f. Replace?
- 1989 2WD pickup: mystery dash harness plug - what does this plug into?
- 1986 Toyota 4wd Front End Problems
- Weber Carb 32/36 Issues
- 22RE AFM idle question
- New Rear Bumper?
- Yes, it is possible to remove to cable from the speedometer cable
- Broke thermal vacuum valve. Can i still drive the truck?
- CV Axel Play at Hub
- 22RE Cold Start Injector Question
- '89 pickup 22re where to buy this plastic fastener?
- Am I crazy? Big tow job ahead
- Gear Oil for Transmission
- 88 Toyota pickup 3.0, 5 speed, manual lock in hub 4x4
- 10w30 or 10w40 for a Phoenix AZ 3.0vze?
- Drain diff oil to pull elocker motor?
- 22RE Horrible EGR Noise Video
