Clutch Release Fork Boot
Old May 6, 2022 | 10:05 AM
B. T. Rice's Avatar
Greetings all. Quick question...Do I have to remove the clutch slave cylinder to replace the clutch release fork boot?
Old May 6, 2022 | 11:32 AM
wallytoo's Avatar
seems simple enough to climb under and take a look. then you'd know.
Old May 6, 2022 | 11:34 AM
B. T. Rice's Avatar
HAHAHA. Yeah, I know. I appreciate the snark. I'm at work and figured I'd ask since I can't climb under it right now.
well played...
Old May 6, 2022 | 12:02 PM
aztoyman's Avatar
You might be able to finagle the new boot on after cutting off the old........maybe. It's just two bolts (12 mm) to remove and the slave will hang on the hard line.
Old May 6, 2022 | 12:19 PM
Melrose 4r's Avatar
5 Year Member
I replaced mine and removed the slave cyl. If you can do it without removing it, more power to you. I didn’t think so.
Old May 6, 2022 | 12:35 PM
B. T. Rice's Avatar
Cool Thanks.
Old May 6, 2022 | 01:39 PM
wallytoo's Avatar
well played...
not really snark. if you think about how the slave works in relation to the fork, you should be able to visualize "climbing under there" even at work.
Old May 7, 2022 | 09:58 AM
Jimkola's Avatar
YT Community Team
5 Year Member
I’d think it’d be infinitely faster to just remove the two bolts. There is almost nothing easier to access on the entire vehicle than the release cylinder. Take all of 30 second for both.
Old May 15, 2022 | 07:32 PM
jazz1's Avatar
5 Year Member
I did not know that boot was available aftermarket. That boot was the first item I sourced off my parts truck
Old May 16, 2022 | 01:53 PM
Melrose 4r's Avatar
5 Year Member
Not aftermarket, OEM Toyota.
JPolk
May 31, 2015 04:10 PM
ktm250exc250
May 7, 2012 07:01 PM
live4soccer7
Nov 5, 2010 08:12 PM
thisgsx
Oct 25, 2010 12:24 PM
NwRunner
Nov 6, 2008 05:57 AM
