93 22re starts with starting fluid
Old May 9, 2022 | 09:42 AM
Melvinfromnowhere's Avatar
9322re ran when I bought it a year ago, been sitting. Needs new gas tank, I have it and a new pump, filter, relay. Hooked up a 1gallon temp fuel tank/12v pump to the fuel line to engine. It starts and runs for a bit on starting fluid, then dies. I'm just trying to move it to a better location on my property to work on it. I don't think it's a fuel pressure issue. Something dumb I'm sure. Please advise, thank you
-Melvin
Old May 10, 2022 | 03:27 AM
Testing
Old May 10, 2022 | 05:32 AM
Blackdoodle's Avatar
Starting fluid bypasses the fuel injectors. Are your fuel injectors clean?
Old May 10, 2022 | 09:08 AM
Robert m's Avatar
With this temporary tank and pump, if the injectors don't have enough pressure behind them they won't spray corectly or at all so if you are using a cheap 12v pump for a carburetor, it won't have enough pressure
Old May 11, 2022 | 04:58 PM
The injectors are good. Sounds like it is a fuel pressure issue, I was just trying to take the shortest path to moving it
Old May 12, 2022 | 11:36 AM
wallytoo's Avatar
how do you know that? right now, your truck is only running on starting fluid, presumably sprayed into the upper plenum. this air/starting fluid mixture gets pulled into the cylinders and is ignited by the spark plugs. your injectors might not be doing a thing, unless you've tested them, or can hear them (which is very possible and easy, once you know what to listen for).
Old Jul 20, 2022 | 04:02 PM
TerryBaker's Avatar
86 22re
  • I've replaced the injectors, fuel tank, fuel pump, fuel filter. Will start and run good as long as I'm spraying starting fluid in it, then dies. Even replaced the ECU. It's got good spark, good fuel pressure. Way to much money in it trying to get it running, can't stop now. It's a 86 Toyota Sunraider 22RE. I could really use some help, getting very frustrated. Lots of hours in and under it.
Old Jul 20, 2022 | 04:18 PM
wallytoo's Avatar
same as for the OP. just because you threw new injectors into it doesn't mean they are doing anything. the fact that it only runs on starting fluid is an indication that the injectors, even if brand new, are not doing anything. test the injector circuit/function. or keep throwing more parts at it.
chrisf
Sep 2, 2019 01:49 PM
Theirons84
Apr 8, 2016 05:22 AM
Griff
Dec 16, 2015 09:57 AM
racerr900
Jun 20, 2004 06:21 AM
