94 Yota Wont Start
Old Jul 27, 2022 | 09:56 PM
HIYOTA's Avatar
Unhappy 94 Yota Wont Start
I've got a 1994 Toyota Pickup, with the 3.0 V6, i just changed the alternator out, and now the truck wont start. After reading threads and searching, I am still unsure what my issue could be. I noticed the check engine light was on AFTER i changed the alternator out, but I have checked my fuses, nothing is blown, fuel pump is cherry, truck turns over but wont start. Any idea's? thought it could be the igniter. Anyone, please help.....
Old Jul 28, 2022 | 04:56 AM
scope103's Avatar
Originally Posted by HIYOTA
... fuel pump is cherry, ...
So?
... thought it could be the igniter. ...
Why?
.... I noticed the check engine light was on AFTER i changed the alternator ...
And what does that tell you?
The CEL is your truck trying to tell you what is wrong. You need to listen. Read the codes.
Though most codes don't lead to a no-start. Put your timing light on each plug wire, then crank. If the timing light flashes, the plug is fired.
Just because your fuel pump is "cherry" doesn't mean it's doing anything. DON'T "crack" a high-pressure connection to see if you can spray flammable gasoline all over the place (if you do that, you must replace the crush washers.) Instead, replace the fuel return line from the FPR to a suitable container. Start the fuel pump by jumpering FP to B+. There is no spec, but I get about 1/2 liter/min. That will tell you you're getting fuel to the end of the rail.
Old Aug 13, 2022 | 10:06 AM
HIYOTA's Avatar
Thank you, I pulled the codes and I am just having a quick flash of the CEL consistently. Not sure where i should go to next?
Old Aug 13, 2022 | 11:25 AM
scope103's Avatar
Did you try the timing light on the plug wires? If no flash there, did you back up and put the timing light on the high-tension lead to the distributor? Did you run all the test for the distributor in the FSM? http://web.archive.org/web/201212070...12onvehicl.pdf
Old Aug 13, 2022 | 01:04 PM
HIYOTA's Avatar
Okay, i will start there, i do not have a timing light though, pretty low on all tools as i just moved to hawaii and have nothing. but ill start there
Old Aug 13, 2022 | 03:20 PM
2ToyGuy's Avatar
A timing light, a multimeter, and a tachometer, which may be part and parcel of the timing light, are tools you MUST have in your tool box. A jumper wire, for use in the test jack. Make it yourself. Terribly expensive, I know, but essential.
Then start in on wrenches, screwdrivers, and so on. Just my opinion.
Pat☺
Thechronicavenger
Dec 10, 2013 07:35 PM
jman101
Sep 1, 2011 08:08 PM
bugeater
Feb 5, 2011 03:38 PM
toy-o-tah
May 28, 2009 06:12 AM
jagermeister
Apr 29, 2008 04:01 PM
