- MSD Ignition Issues when trying to use OEM tach.
- High Performance Rad for my 3vze?
- 86' 22r carburetor problems
- How to replace sliding window?
- AFR Compensation?
- 90 4runner steering issue
- Main Caps not interchangeable?
- swing tire carrier
- alternator issues
- 95 4Runner Differential Rumble
- HG or timing chain?
- W-56 wont go into 3rd gear
- Turning Diff upside down
- Rubber isolators for LC80 springs
- Two Quick questions
- Camper shell quick mount
- 22 r 86 4 runner
- PCV hose broke
- 1988 22RE ECU giving multiple codes
- Want to go back to stock body height
- '88 4Runner - Exhaust Fumes in cabin.
- intermittent code 25
- Does this truck look familiar to anyone?
- 22r water not circulating
- 90 4runner doesn't wanna start
- 93 4runner AT fluid question
- Tilt Column Swap ??
- 22r Oil filter Shoot out
- Swapping a Cali ECU for a non-Cali
- '87 pickup 22r fuel guage misreading
- 1995 Toyota Tacoma 22RE Loping
- Abnormal deceleration
- Is there a reverse light relay on 1st gen 4Runners?
- my new roof rack
- heater core leaking
- 3.0 problems
- 93' 4WD Power Issues...need HELP?!?!
- HELPP:(1990 toyota 4runner auto, it wont start, seems like a very complicated problem
- shhhhh!!! quiet 22re
- 88 4x4 truck blown head gasket???
- Got to try my 4wd for the first time in snow.
- can you put a powersteering box from a 87 4runner on a 91 toyota pickup?
- 91 v6 5 speed: tranny issue
- '87 22R P/U Idle issue
- CEL Code 12 - No RPM Signal HELP!
- Headlight swap:Square to Round
- roof rack
- 95 4runner A/c problem
- Gauge swap
- Engine noise at cold start and sporadically when depressing brake
- Broke knock sensor tip
- idle problem please help!!
- I think my 88 4runner is dead
- 33" PICS please!
- 200,000
- has anyone tried rebuilding their clutch master cylinder?
- Cost to rebuild
- 35s & minimal lift Yet another tire fitment Q...
- Truck dies, then restarts after i pull the coil wire and test it.
- wandering in snow in 4wheel, not the snows fault.
- Ring and pinion
- 22R cold start question
- Yet another 3.0 header install question
- dead cylinder 3.0...new engine? or sell?
- motor start and running issues
- weight of Hardtop on 86 4runner?
- Cracked tranny housing
- OME coils and brake lines
- 89 4runner radiator exploded?
- 86 factory air interchangability
- 22re Runs rough sometimes
- 92 Pickup Trouble Cranking
- Truck keeps cutting off then wont start!
- Any words of wisdom for installing 3.0 cyl heads?
- 22re gas mileage, What are u getting?
- distributor question
- Code 12?
- What is this
- Fix a lazy tachometer!
- I used the iPhone "Pockey Dyno" to get the 1/4 mile time on my 4Runner
- Stamping On The Igniter
- 22re ticking/ Possible knocking
- Another Zuk Mod question thread
- Hard to start after sitting a couple days, sputters on highway - help diagnose?
- 4Runner won't rev above 2000 RPM unless ECT enabled
- Junking '90 4runner What Parts to Keep
- 95 4 runner 3.0 spark plug broken off!
- 88 22 rec diagrams?
- Binding issue while in 4 wheel drive
- Shower set-up in my 1986 4Runner
- Strange intermittent noise from hub when locked
- Knuckle service
- 90 22RE will fire over then cut right out...stumped
- Knock sensor help...
- Overheating after timing chain swap
- 3Vz connections
- Code 14 making me go bald
- Front sway bar rubs front driveline
- mushy clutch pedal feeling? why?
- truck starting problem
- 1991 4Runner 1JZ Engine Conversion
- 1987 22RE okay without the dashpot?
- U Joints size question
- toyota 4 runner 1995 engine pulsations.
- blown head gasket....
- Are V6 diffs a direct swap for a 4 cylinder?
- Sent out 22RE injectors for testing/cleaning
- top shift t-case wont shift into 4x4
- 88 toyota pickup horn worked but now it dont?
- 1989 Pickup 22-RE Idle & Sputtering
- My low idle/no idle TPS story (good ending)
- 1986 Runner Trans question
- Failed Smog w/ High NOx after blown head gasket - where to start
- New fan cluch, new coolant leak.
- coolant in my oil - headgasket isnt blown..
- Replacing Pickup CV's with T-100 CV's ???
- will not start after new radiator!
- Coolant Overflow, No Heat, Surging/High Idle Pulling my hair out
- ANother TPS thread...Im sorry!
- Crank Shaft Key
- 94 Pickup Lighting Issues
- PCV on 3VZ-E
- 22RE Fuel Issue
- 86 22 r crazy electrical issue
- Timing sprocket removal
- 1990 toyota pickup tj coil zuk mod
- Sealing backup light switch on 5spd?
- Curt Hitch Install - 1st Gen 4runner
- 22RE Lower Pump to Pipe Coolant Hose Replacement
- 4Runner 94' Weak Transmission?
- No more ghetto exhaust
- took the wrong path...oops
- emergency fuel cut off switch?
- 22re wont rev past 2000k rpms
- Bilsteins
- 22re wont start
- Bizzaro electrical issue after hard bump, turns but doesn't fire
- another turbo truck build??? help with what parts to get..
- 22RE Problem.
- 3.0 Distributor
- Idler Arm quick question
- smoke smoke and more smoke
- Temp raises with heater on
- 95 V6 fuel filter and hard lines
- Trouble shooting oil leak coming out from slave boot?
- Sliding rear window questions 1990 Pickup
- Location for U shaped coolant hose on back of head/block of 86 22RE?
- 22re cranking not starting...
- 1988 22RE Weird Problem Radio Not Working Even After Replacement; Hazard Lights Out
- Cleaning the AFM
- Rusted cylinders, salvagable?
- 22re throttle body replaced, now running problem
- SR5 tach off !! Help !
- 70 1/2" drive shaft?
- Torquing the cam bearing caps - 3vze
- Crank pulley TDC notch incorrect?
- Rough ride 89 runner
- 95 4Runner odd transmission problems.
- 1998 2.7 oil leak
- Turn signal/headlight combo switch part number?
- VSV models/years?
- All red tail lights
- Best Flywheel and clutch set-up(bang for your buck)?
- Pickup Temporary Rear Leaf Fix?
- charging system woes
- fuel help
- lighting?
- so that's a BAD thing when that doesnt spin?....
- Reverse LEDs
- 86 idle problem when brakes are applied
- Help with TPS readings.
- 22re misfire 1 and 3
- Random Surging/Hessitation
- 93 4runner, 3vz-e, over heats
- 22r computer....
- Does 91 go into 87?
- Overdrive OFF /trans issue?
- Move transmission to replace T-Case?
- Anyone have regrets on doing BJ spacers and ZUK mod
- clutch replacement - tips?
- Valve shim suppliers? Need smaller than 2.20mm!
- 92 22RE will not hold idle
- Quick Thermostat Question
- help with automatic to manual window conversion
- Rocker Arm Cover
- Oil Leak
- Not Cranking
- Sterring Wheel locked in on position
- 3.0 oil seals
- Remove instrument panel(upper dash)
- Need help wiring ignition ignitor
- Rear brake question - LORORS Mini-Stock
- Lares Steering Gear Box Quality?
- Cracked block? Options?
- clutch slave bleeding weirdness... thoughts?
- Help with Auxiliary Fuel Tank Repair Problem
- 86 4Runner starts and then dies
- Power steering leak
- Q&A help with possible blown rear diff
- Ok to have head cleaned with valves installed?
- end a helping hand in Portland this weeked?
- Clutch Bracket almost done, need some help!
- ECU fitment question. What ecu fits what?
- lower shock bolt size?
- Ext cab bed and short bed
- will rear window from a 90 fit an 87
- HELLLPP electrical problem
- 2WD Low Range
- rear bump stop length, 2ng Gen 4runner
- Question about head gasket
- 87 22R pickup runs ruff at idle when cold/ Runs rich
- I'm going to buy a 4Runner and it is going to be awesome.
- Engine Coolant Temp Sensor Plug Broke!
- Throttle Body Vacuum lines
- acceleration prob.. help please
- Ruff Tuff Saddle Blanknet Seat Covers?
- weber carb choke question
- Coolant leak. Is it a head gasket?
- transfer case problems
- No compression in the #1 cylinder
- blown transmission or seized? options?
- Dead spot in TPS?
- TPS issue...
- time for new rear brakes, options options...
- 88 22r no spark with 12V to coil
- 88 4runner auto transmission problem
- Taco Springs on 91?
- 88 Toyota pickup still not starting!!
- Rear Tailgate Plastic Clip - Part Number - 88 4runner
- 4runner lift on pickup
- fuel mileage issues....help me out here
- Bad fuel sending unit blowing efi fuse?
- 3.0 tps
- 3VZE Low Idle
- "RH Ground Strap" OBSCURITY
- Battery Light Confusion!
- 94 runner CV binding issue
- "Pop" and then no brakes! Schnikies what do I do?
- engine swap
- electrical grounding starting issues on 1990 4runr
- EBAY HID Headlight kit
- Painting entire vehicle with bed liner...help.
- 88 pickup wont start, really odd
- '87 P/U needs rust repair
- Truck smells of ATF while idling
- Dash pad install and Paint pics
- Best transmission rebuild kit
- Regear a good idea?
- I think I fried my ecu!
