88 4runner auto transmission problem
Old Jan 7, 2012 | 03:14 AM
zukyota's Avatar
I have an 88 4 runner with the 3.0 v6. A friend had a auto transmission from a 92 4runner swapped in. The transmission will not shift. I can drive in low, shift to second, then shift to drive & then nothing. It will drive but no shifting. The speedometer is not hooked up. Could this be the prob? I'm not sure if the guy that did the transmission swap put the transmission computer in from the 92. Where is the computer for the trans located on the 88 & the 92 4 runner so I can check? Thanks for the help.
Old Jan 7, 2012 | 06:45 AM
Mr.Utah's Avatar
Just guessing here, check your fluid level. Or even drain and fill. If problem continues, maybe its rebuild time? Oh, the speed cable should have no function in the transmission mechanical use.
Old Jan 7, 2012 | 08:49 AM
zukyota's Avatar
Not really wanting to spend alot on the auto transmission & I can buy a 4. 3 with the harness &the computer for $150.00 so I'm thinking of swapping in a 5 speed from a 93 model. Would this transmission hold up to the 4. 3 ? I can buy the 5 speed with transfer case for $550.00. Is that a good deal?
Old Jan 7, 2012 | 01:32 PM
zukyota's Avatar
Any suggestions, tips or ideas ?
Old Jan 8, 2012 | 05:27 AM
zukyota's Avatar
Come on guys, I need advice! My runner just sitting in the driveway is killing me.
Old Jan 9, 2012 | 03:07 AM
zukyota's Avatar
The transmission control in the 88 is a 3vz. If it has a 92 auto transmission what transmission control should it have ?
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
vasinvictor
Jan 20, 2016 12:39 PM
94whiterunner
Sep 22, 2015 07:25 PM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
ACZR
Jun 23, 2015 07:55 PM
