Sealing backup light switch on 5spd?
Old Jan 15, 2012 | 01:00 PM
stanz's Avatar
I have have an 86 4Runner 22RE/5 spd. My back up light switch needs replaced. I know it's a simple R&R, but wanted to ask if I should expect oil behind the switch.
I noticed what appeared to be sealant on around the edges of the existing switch.
Want to be prepared and have sealant ready if needed.
Thanks in advance!
Old Jan 15, 2012 | 02:04 PM
MudHippy's Avatar
No, there shouldn't be any oil behind it I don't think(unless your tranny is too full). And the FSM doesn't specify any sealant to be used when installing it.
Old Jan 15, 2012 | 11:34 PM
wyoming9's Avatar
Red face
I just use Never Seize on the switch and fill plugs.
there might be a little oil but it should not come pouring out
Old Jan 16, 2012 | 01:25 PM
abecedarian's Avatar
You could get some gear oil out of it when removing the switch. Just be sure to double check the fluid level at the fill plug (on level ground) after working on it.
It's a two-terminal switch and doesn't ground through the transmission so a little RTV or similar should be okay to use on the threads, if you feel so inclined.
Iceman4193
Jul 15, 2015 04:48 PM
andrewtexas123
Jul 14, 2015 04:29 AM
Johntom240
7
Jul 13, 2015 12:18 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
colinmil
Jul 6, 2015 04:03 PM
