86 4Runner starts and then dies
Old Jan 9, 2012 | 08:22 PM
andlours's Avatar
So this has been happening for a while with my 4Runner. It only happens after it's sat for about 5 hours. I turn the key and the engine cranks, it catches and then immediately dies. After I do it a few more times it will finally fully start. Also, if i give it gas at the start it'll start first time, every time. I've heard about cold start injectors going bad, so i recently pulled mine out and gave it a thorough cleaning, but I've noticed no difference. Could my CSI just be completely bad or is there another issue that I'm missing?
Thanks,
Andy
Old Jan 9, 2012 | 08:47 PM
BMcEL's Avatar
Test/clean the AFM. Sounds like the vane isn't opening enough. That would explain it starting when you give it some throttle...more air to push the vane open.
Old Jan 14, 2012 | 11:11 AM
andlours's Avatar
Well, I recently got an '82 Supra AFM, but I don't think that's necessarily the problem, because it did the same thing before I swapped it out for the new one. Any other ideas of what may be going wrong? If this helps at all, it also idles really low at start up. I don't know of the two are related though.
Old Jan 14, 2012 | 03:49 PM
mattches's Avatar
Did you check for voltage at the CSI? Or try taking the CSI out and sticking it in a jar while you crank it, see if it shooting out gas? If it is working okay then maybe a throttle position sensor issue, or a loose vacuum hose?
Does it have any problems while it is running? Like surging, stalling, missing? Error codes?
Old Jan 23, 2012 | 06:21 PM
andlours's Avatar
Well i haven't gotten a chance to look at everything quite yet, but ill certainly go through and check everything. I'll let you know what i find.
sonic concepts
Aug 16, 2025 03:13 PM
91toybeater
Dec 27, 2015 07:46 PM
puffin04
Jul 10, 2015 09:17 PM
MadMax48
Jul 3, 2015 08:26 AM
slider417
Jun 22, 2015 10:18 AM
