4runner lift on pickup
Old Jan 6, 2012 | 04:43 PM
ItsJustD's Avatar
Hey, I got a 93 toyota pickup v6 ext cab 4wd..... I recently found a procomp 4" lift on a 4runner at my local pick a part yard, I was wondering if the 4runner and pickup IFS lift would be the same. I already got my chevy springs, sorry for the noob question... I'm young and don't know much about IFS but learning....
Old Jan 6, 2012 | 05:01 PM
abecedarian's Avatar
Any front end IFS lift from 86-95 should work on the front of any IFS truck,
86-95. Rear's are obviously different depending on the years and truck or 4Runner.
That help?
Old Jan 6, 2012 | 05:20 PM
ItsJustD's Avatar
Yeah thanks, I figured it would... But I wanted to make sure before pulling it out and buying it to find out it wouldn't work...
Old Jan 6, 2012 | 05:31 PM
No prob.
Old Jan 6, 2012 | 05:32 PM
rattlewagon's Avatar
It will work, but youll have to do something different about the rear of your truck. Make sure you get ALL THE PARTS. If you can have the yard cut the front half of the frame off, do it. (I love when they bring out the torches )
Old Jan 7, 2012 | 10:20 AM
Yeah, definitely make sure you get all the parts.
The front half of the ProComp kit should include:
- 2 steering knuckle extensions
- 4 lower a-arm mount brackets / extensions
- 2 front differential mount "drop" extensions
- 2 sway bar / frame mount "drop" extensions
- 2 low profile urethane bump stops- I suggest having the factory stop in place at the front stop mount and the low-pro stop installed at the rear mount
- 1 bolt in rear a-arm crossmember / brace- factory doesn't have one in the rear
- 2 reinforcement struts- bolts to the rear lower a-arm extension and transmission support crossmember
- 2 extended shocks- the stock shocks will be too short to use
It does not come with extended brake lines- I suggest braided stainless over longer rubber hoses for those, nor does it come with a skidplate- the factory one won't work, nor has it a steering dampener- factory will work since the steering linkage is mostly unchanged from stock locations but it may not be up to the task of handling larger tires and different rims.
6th Gear
19
Dec 10, 2019 07:31 AM
live4soccer7
Sep 3, 2015 12:29 PM
duckhead
Jul 17, 2015 04:45 AM
Tommy T.
Jul 5, 2015 07:48 AM
Dylan199119
Jun 25, 2015 09:54 PM
