so that's a BAD thing when that doesnt spin?....
Old Jan 12, 2012 | 08:49 AM
Pistol_Pete's Avatar
So my alternator belt breaks on my 91 rrunner.
All back on and new belts. Went to spin the engine a hair to get the final fan bolt back on and noticed the pulley is not turning. Alternator belt is turning, but not the water pump pulley.... uh oh?
Old Jan 12, 2012 | 09:03 AM
scope103's Avatar
6-cyl 3VZE?
If the water pump pulley isn't turning you're really screwed; you broke the timing belt.
But the timing belt doesn't go anywhere near the alternator. I'm going to guess the fan is what's not turning, and that's attached to the "Radiator Fan Clutch Bearing Bracket," $135 at RockAuto.
When mine broke (it actually twisted the bearing out so the fan dipped into the radiator), the mechanic (I was a long way from home) said he'd never seen that before. But others on this list have.
$135 is not chump change, but I would advise against trying to press out the bearing to replace just the bearing. It's an aluminum casting, and once the bearing failed it could have twisted up the seat. But it's your choice if you think you have a source for the bearing only.
Old Jan 12, 2012 | 10:22 AM
snap-on's Avatar
On the 3vze the acutal water pump is driven by the timming belt which is under the black covers.
The fan belt and alternator belt run on a "false water pump bracket" that mounts to the front of the engine.
If that pulley (the one the fan is mounted to) is not turning your going to need a new false water pump bracket. Its sold as an assembly, you can not just by the bearings for it. (note that you get the right one for your 3vze, based on hydrualic timming belt tensioner or spring version)
Old Jan 13, 2012 | 07:51 PM
Hey you guys are pretty freakin brilliant!
Thanks for the help...sure nuff, there she was, broken bracket.
Appreciate it. Will be installed and back on the road this weekend -
Old Feb 9, 2012 | 11:01 AM
MaK92-4RnR's Avatar
My bracket has broken twice since owning my truck. the first one the entire rod/bearing pulled out and jumped all the belts off the front of my truck. had to drive home with no power steering. :/
Eggslinger
Jun 8, 2019 03:32 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
pyramid
Jul 30, 2015 10:05 AM
calderp
Jul 27, 2015 09:58 AM
PlayAwhile
Jul 20, 2015 11:36 AM
