22RE Lower Pump to Pipe Coolant Hose Replacement
Old Jan 15, 2012 | 09:47 AM
stanz's Avatar
It looks like I have to remove the PS pump to get the water pump outlet to replace the pump to pipe hose on my 86 4Runner 22RE. Is this correct? Any tricks without removing the pump?
Thanks!
Old Jan 15, 2012 | 11:01 AM
skypilot's Avatar
No; you just have to spin the clamp around till you can pinch it with pliers. Then you get to fight it loose. I use one of those TV cut anything including a hammer knives to cut the old hose enough to minimize the battle.
Old Jan 15, 2012 | 12:24 PM
stanz's Avatar
thanks. I had to leave that one alone for now. 10 hours of working in the freezing rain and now snow was enough for me. I got every coolant hose replaced except that one.
All new coolant hoses (except one), new plugs, cap/rotor, sealed up the remaining vacuum leaks and it's running better than ever!
Spicer
Apr 7, 2026 07:17 PM
Team420
Jan 12, 2021 04:57 PM
voiddweller
19
May 2, 2016 09:10 PM
puffin04
Jul 10, 2015 09:17 PM
infinityisfive
Jun 16, 2015 06:51 PM
