- 2nd Gen grille guards...
- Replacement cv front axels
- Hubs not lockin? No 4x4 HELP!!!!
- Where can I get chrome wheel well molding?!??!
- Polishing a turd (3.0)
- parts for 3.4 swap
- 22re timing chain
- Weird Problems with the Rig...Help, Please
- Specs for machining a 3vze flywheel.
- 22re Strange Behavior
- CV boot maintenance
- Removing tranny from 86' 22RE 4runner
- 94 2WD Power Steering Gearbox
- Factory Oil Filter
- factory 4.88 help
- Bearing Cap on an 3.0
- What a day! CV joint experiance! BUILD UP THREAD...LOL
- Any chance this ISN'T a head gasket???
- gettong an 88 4runner and need some advice
- problem after timing belt replace
- New 4runner owner: Rust, Leaks, Exhaust and More!
- downey dual shock kit w/ bilstein 5150????
- Correct Stall Speed?
- 22re oil pickup questin
- Which clutch set to buy for 3.4L swap
- squealing noise when clutch is out
- No 4x4
- Stupid annoying driver door!
- Tinting my 94
- 22re= No POWER?!
- Ls 400 injecters
- Can't start
- 89' Lower valance
- 1st gen sr5 wheel vs. 2nd gen sr5 wheel ???
- Best place to buy aisins on line
- coil to leaf conversion
- engine grease during rebuild
- Best clutch for the 3VZE
- replacing upper ball joint
- Coolant Everywhere!
- smoke ring from the tailpipe = valves out of adjust?
- Burning oil smell at startup, leak from where? 3.0
- 88 22r odd sometimes erratic idle
- 3vze compression test
- Old problem comming back
- 2.7L Problems....need feedback.
- auto shifter
- hilux head gaskets
- 86' 5 speed upgrades *pictures* updated often
- Towing with a 3.0
- DOH lost wheel lock??
- 22RE With NO Compression
- Yikes! 3.0 smokin' and dyin'
- Replacing the center support bearing.
- altenator testing question
- Part # for o2
- 3.slow, should it stay or should it go now?
- 3.0 Stalling/Power Problem
- It was rich then light brown
- 86 4Runner Rear Sag
- What brand fender flare's are these? PIC INSIDE
- transmission removal problems
- A340H temps
- possible blown headgasket?
- Wierd demon 22re
- alternator belt HELP
- Best place to buy a good used entire rear axle
- Clicking noise from my 3.0, any ideas?
- Door won't open on '94 4Runner
- L / R seatbelts the same?
- 3.0 still hard to start?!
- OME 901 coil lift question on my 95 4Runner
- '95 4Runner - Fuel Injection System Problem?
- '95 4Runner - Strange Noise in fender
- What is that "dampner" on the throttle?
- Replacing rear wheel studs? Prices quotes?
- 22re question for the gurus
- Transmission Noise
- Loping 22re
- Drivetrain Lift
- Lifted the rear now the front???
- AFM air flow meter flap not operating correctly???
- 3.0 knock question
- Installing OME springs-- need brake line?
- low oil pressure, please be the sending unit
- 3VZE & oversize valves
- Knocksensor Problem
- steering clunck
- Friction/Rubbing from Steering on Start-Up
- 93 3.0 hesistating on accel
- Emissions diagrams
- Hood Insulation questions!
- HP. or TQ. what ever it is I need it
- Man, am I stoked!! Tailgate window fixed.
- Toyota doesn't carry my part! Help!
- 3VZHeat Shields
- 86 Runner cap
- Stock coil spring height?
- Idle problems 3vze 3.0L
- Tailgate Decal Font?!
- Panhard Bar Question
- Big Tires On A Stock 95 4runner
- Are my torsion bars cranked??
- Help Identify These Engnbldr Gaskets...
- Sunroof drive cables are RIDICULOUSLY Expensive!
- Need Help/Advice: Is my Toyota's Long Travel Suspension Set Up Wrong (too stiff) ?
- idles for a minute and no response from accelerator
- fender flares
- New paint and herculiner for my 1st gen! PICS
- Stupid question about oil filters
- Should injector be replaced?
- honeing a motor
- "Locked" Front diff
- Any one know if turbo engines require a special radiator
- Transmission Woes
- 2007 Yotatech Calendar
- 1992 3.0 surging and idles high
- Bent steering knuckle on my 95 4runner?
- Rate my '94
- power steering fluid type
- TPS feeler gauge
- Tps
- V6 Fan Bracket Bearing Replacement
- 1987 4x4 body panels
- 92 4runner oil guage problem
- cleaning intake mainfold
- MAF problem on an '87 EFI
- aftermarket air conditioner opinions please
- 93 toyota pick up 4cyl. knocking and squealing??
- Heating up and smoke from tail pipe?
- Mileage Problem
- Jet ECU Reprogram for 22RE
- 1991 pickup 4x4 rusted out oil pan ?
- Rough idle after rebuild 22re
- Help pricing pickup parts
- 86 truck part alternatives
- AC charging questions.
- ?? for those who have broken front axles, Gen II 4 Runner
- need help with timing
- Air Flow Meter
- What can the ECM do?
- Removing rotor/hub
- bucking/miss in 3ltr 91 4wd p/u
- Quick question before i drop the trans.
- 22r engine interchangeablility
- 3.0 Timing Belt Tension
- So how to improve gas mileage on a 22re?
- Can someone take a picture of their battery for me?
- Need transmission removal tips...mines stuck
- Not your typical "cam" question
- window problems
- Stuck crankshaft pulley bolt on 22R
- Correct timing on 1987 4runner 22R-E calif
- How can i find out how much my gas tank holds?
- Temp Guage Going Crazy
- Yes, another backspacing question
- Removal/Instal of Axle Flanges
- Repair estimate
- Full floating axle lube
- help w/ebay parts
- What size in the fuel filter/hardline connection?
- neutral park switch location 95 4runner
- 1995 4runner A/C not working
- Cylinder Problems
- engine rebuilding tips?
- ct-26 on my 87 runner?
- Seat swapping options
- rear axle rebuild needed! Is it a do it yourself or stealership job! wheel bearing!!
- BIG 3 wire upgrade?
- NWOR headers?
- PAIR Reed Valve
- Master Cylinder?
- Gas Tank Relocation?
- BHG or Tiny Leak??**Long**sorry..
- Valve adjustment and timing
- Electric Problems
- help 4runner stalls after a couple of seconds
- lowering a 4x4
- Shift Lever Removal Question
- 4" IFS lift found
- 4Runner engine, speedometer, etc help
- 22re ECU Help
- 1990 4Runner Head Gasket Recall Honored
- 92 3.0 Cold Start Issue
- 22re Engine Clatter??
- What shocks do i need?
- Failed SMOG Check. HELP
- rocker vs. headgasket
- bench seat
- painting the block of a 22rtec
- 3.0 Timing Belt Tensioner
- Desert Truck Needs an Engine Swap, Any Ideas?
- Clutch boot replacment?
- flywheel bolt info
- Alternator wiring upgrades???
- hooking up winch power to optima batterie
- rolled on paint
- valves click
- need fuel filter help ASAP!
- 16x10 wheel backspacing?
- needs more kick
- Vortec V6 or LS1 V8
- Oil Leak near the Oil filter with pics
- new member with an 87 4runner DLX
- in search of brush guard for 87 4runner
- Starting Problem
- Two pretty simple questions
- 3VZE Blowing oil
- What other Year and models can i get parts from?
- Do you have a Timing Belt "How to guide"
- Anybody have Electric windows?
- head gasket vent
- 1986 5 speed transmission replacment
- Whats wrong with this picture? (22RE rocker assembly)
- Timing Belt Help ASAP
- OME Steering Stabilizer Installed
- 91 4runner starts then stops
- pics of my newly lifted truck
- any body know turbo charging in milwaukee wi. area
- Nippon 08922-02011 Oil Filter
- speedometer bouncing
- Need help with a rear window channel
- lend a hand
- Camshaft Spocket or Gear
- 95 4runner 3VZE engine miss
- 86' 5 speed tranny trouble
- Rancho Steering Stabilizer
- Performance Products OE style seat covers
- Need some gas when starting...?
- Weird cooling issue w/ 22re
- motor questions 3.0
- Dancing Speedometer
- 1989 4x4 w/tacoma wheels
- k&n install pics needed
- 3 core Radiator
- Air Flow meter
- Driver's side hub warm to touch and making noises
- installing new oil pump
- 22re swap electrical pob
- In Search of Nerf Bars for 87 4Runner
- Tourque specs
- 3.0 oil consumption oddity? Anyone else?
- Difference in gas mileage between 30" and 31" tires?
- 3.0 died and wont start, stranded at work
- lift opinion
- Spring removal help needed
- arb bumper
- Heater and Blower Questions
- CEL code 71 on a non-cali vehicle...
