1992 3.0 surging and idles high
Old Oct 1, 2006 | 09:11 AM
nineball's Avatar
1992 4runner V6, when you crank it cold it idles fine most of the time, after it warms up it either surges or idles high. There is no check engine light on, it also has a miss you can feel under normal acceleration but can't feel at WOT, anybody had similar probs?????
Old Oct 1, 2006 | 09:31 AM
yota_krazy's Avatar
that sounds like a vacuum leak to me. When it is idling high/surging spray carb cleaner around the base of the intake plenum and any visible places on the intake side and note any significant changes in idle speed. It should make a big difference when you hit the money spot. Good luck
Old Oct 1, 2006 | 10:49 AM
Elton's Avatar
does sound like a vacuum leak
Old Oct 1, 2006 | 08:11 PM
mtnfreak's Avatar
I'll say vac. leak as well. Any work done under the hood recently? Does anything change when the brake pedal is pushed in? Does the engine ever come off of cold-start?
smthwsn357
May 1, 2024 07:28 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
kyletbert
Jul 17, 2015 11:39 AM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
ZONAYODA
Jul 13, 2015 07:17 PM
