installing new oil pump
Old Sep 24, 2006 | 11:31 AM
xentrino's Avatar
This may be a stupid question but I haven't been able to find the answer anywhere. I'm installing a remanned 3VZE in my 94 runner. The engine came with an oil pump but I have to install it. Is it safe to assume that the pump gears have already been packed and all I need to do is install the pump? I started to remove the gear cover but the philips head screws seem to have been installed with tread lock and I'm not sure I can get them out w/o tearing up the slots.
Old Sep 24, 2006 | 11:57 AM
mt_goat's Avatar
Originally Posted by xentrino
Is it safe to assume that the pump gears have already been packed and all I need to do is install the pump? .
I wouldn't assume anything. I'd at least contact them and ask.
Old Sep 24, 2006 | 01:17 PM
Yoda's Avatar
I don't pull them apart. I pour some hiltons, stp, motorhoney,....some thick lube supplement into the opening and turn the pump to work it into the teeth. Gives you max suction when you crank the engine up.
Old Sep 24, 2006 | 05:05 PM
dcg9381's Avatar
I know the 22re pump I bought from Ted a few years back was not pre-packed. The one I bought from DOA recently (cost about 3x as much for a high-vol deal) was packed...
I'd pack it for sure....
Old Sep 24, 2006 | 05:24 PM
ovrrdrive's Avatar
Packed with what?
I always use vaseline...
Works like a charm and the first oil change comes 10 minutes after I start it anyway.
Old Sep 24, 2006 | 06:06 PM
xentrino's Avatar
Turns out it was already packed so no worries. Thanks for the advice!
bigjstang
Jun 2, 2025 03:56 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
87blyota
Jul 10, 2015 04:31 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
bryan34w
Jul 6, 2015 05:53 PM
