Need some gas when starting...?
Old Sep 25, 2006 | 04:08 AM
tomasp's Avatar
Question Need some gas when starting...?
When I start in the morning usually it takes a couple of secs to crank until it starts. However if I push accelerator a bit and crank holding it then it starts immediately. What could it indicate? New plugs/cap/rotor, all stock. Clean cold start injector, clean injectors, 11* ignition, idles like Swiss watch. The only thing old is ignition wires - I think they are made in 1992
Also when hot and i crank it sometimes it looks like it hasn't started but then it starts up. I.e. I crank it for a moment, release the key but the motor is not started, however as soon as I release it - it comes up...
My AFM is leaned 1 notch so the spring is stiffer - I was thinking maybe the fuel pump is not engaging early enough so connected it manually but it didn't make any difference.
Old Sep 25, 2006 | 07:25 PM
silversup's Avatar
do you get a strong fuel odor when you try and start it several times?
Old Sep 25, 2006 | 07:40 PM
tomasp's Avatar
Nope, never gas smell...
Old Sep 26, 2006 | 05:20 AM
silversup's Avatar
Last time I saw a prob like that it was a faulty fuel pump. We would crank the car several times and finally it would catch. The fuel pump was not dead but took a while to build up adequate pressure to start the car. After, the fuel pump was changed we never had a problem since. Also, check to make sure your fuel filter is not clogged.
Old Sep 26, 2006 | 05:31 AM
rollem's Avatar
X2 on the fuel filter. I wonder if that AFM mod has something to do with it?
Old Sep 26, 2006 | 05:38 AM
farmerj's Avatar
I would second the fuel filter before anything else. Do you know when it was last changed?
I use a paint stick and write the dates and mileage on my filters when they are installed.
Old Sep 26, 2006 | 05:48 AM
silversup's Avatar
That could definitely be a possibility but I would imagine that would just make your rig run rough if that was the problem. I think though however when you start your vehicle, cold it is in Open loop mode. In that mode you car will inject a fixed amount fuel/air in the engine to start. If that pump is not functioning properly this cannot happen. If you have a spare afm definitely swap them out to see if thats your prob or get your fuel pressure tested.
Old Sep 26, 2006 | 05:54 AM
rollem's Avatar
I've read alot on that AFM mod and it seems like everybody that does it, has erratic fuel issues. I'm a bit skeptical on this mod and question it's reliability...
Old Sep 26, 2006 | 07:37 AM
silversup's Avatar
Keep us posted on what cures the problem. i am interested to see what it is
Old Sep 26, 2006 | 08:15 AM
farmerj's Avatar
http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Check that out.
Old Sep 26, 2006 | 01:06 PM
tomasp's Avatar
Thanks everyone for replies.
Fuel filter is brand new and I did check the "cheap trick" from 4crawler site - even if I pre-run fuel pump for 10sec or so before cranking it makes no difference.
pickle6415
Oct 19, 2015 08:08 AM
larrys93pickup
Sep 17, 2015 07:05 PM
AlexJet
Sep 14, 2015 09:00 AM
gp66
Sep 14, 2015 12:10 AM
Boomer8404
Sep 10, 2015 09:01 AM
