Rancho Steering Stabilizer
Old Sep 25, 2006 | 06:03 AM
Exeter's Avatar
I've got a 1994 4Runner and I'm in the process of getting new shocks and steering stabilizer, but I've run into a problem. At this link, http://store.summitracing.com/egnsea...=KeywordSearch, it says these will work with up to a '93. I have a '94, but are they actually different up there, or would one of these work? Any help, or personal experience would be greatly appreciated.
If link doesn't work P/N's at www.summitracing.com are
RAN-RS5402
OR
RAN-RS97273
Old Sep 25, 2006 | 08:22 AM
Exeter's Avatar
wanna get these ordered soon.
Old Sep 26, 2006 | 09:54 PM
Neaners's Avatar
I checked about 5 different sites that had the rancho stabilizers... they ALL said Steering Stabilizer for Toyota 4 Runner 4wd/2wd 86-93 - Couldnt find even one that specifically said for a 4 Runner any newer. So looks like you are out of luck on this one ..
Old Sep 27, 2006 | 05:59 AM
MonsterMaxx's Avatar
93 & 94 are the same in pickups. Don't know on the Runner, but I didn't think they moved to the next gen until '95
BTW: I have this stabilizer, have had for 10 years. Works great and has lasted very well.
Old Oct 2, 2006 | 07:57 PM
Exeter's Avatar
Ack!
Well, I ordered the Rancho Kit for the '93 (my truck is a '94) and somthing silly happened. The hardlines for the tranny cooling lines are in the way.
This kit doesn't bolt in the same place as the stock one, rather it goes parallel to the relay rod, (i think?), and bolts to the relay rod with u-bolts and some nuts on the drivers side. On the passenger side, there is a bracket that goes on the inside of the frame rail, using the holes where the idler arm attatches to the frame. My g/f has my camera or i would take a picture.
Basically, i can get it on there, but since it moves whenever i turn, the hardlines are being moved with it. And i'm pretty sure that's not a good thing.
Any suggestions? Send it back?
Thanks.
Old Oct 2, 2006 | 08:08 PM
yota_krazy's Avatar
they must be different between 93 and 94 so i would say send it back and get the correct kit.
Old Oct 2, 2006 | 08:27 PM
Exeter's Avatar
Thing is, this is the only kit i could find at summit, or according to others, anywhere. I will do some more searching, but maybe a different brand is in order? One that bolts directly into the stock holes?
Thanks for the reply.
Old Oct 3, 2006 | 04:26 PM
traben27's Avatar
i put the OME steering stabilizer on a few weeks ago and i'm really happy with it.
its probably a little more expensive than the rancho, but i'd say its worth it. try trdparts4u.com
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
live4soccer7
May 11, 2016 06:52 PM
scott90
Oct 4, 2015 09:21 AM
ktm192k
Oct 1, 2015 08:47 AM
