Coolant Everywhere!
Coolant Everywhere!
Hey there, I am wondering if anyones know where the leak came from. I turned into a gas station got out and noticed coolant POURING out from underneath. I tried to look to see where it was coming from, but all I could determine is that the radiator is fine, resevoir is fine. the leak looks like its back a little.
91 4-runner V6 3VZE
91 4-runner V6 3VZE
Man, I replaced it (the water pump) less than a year ago.....I hope not that was a little time consuming. I'm going back to check and see if I can pinpoint it. If I remember correctyl the majority of the puddling was closer to the Passenger side front tire if that narrows it down.
Im going to scare you even more...
I had the same thing happend about 6 months before my BHG showed any signs. I had broken my lower radiator hose clamp so I used 2 cheapie hose clamps on it. It still leaked and I attributed it to and old hose and cheapie clamps. Because of this it would leak when the system was pressurized....
Well unbeknownst to me, my #6 HG failed internally, ever so slightly and it would over time pressurized my coolant system! Over the period of a month I'd have to add about 1/2 gallon to the coolant system. As time wore on it got worse, then one day when I went to start one cylinder wouldnt fire until warmed up!!
I hope its just your radiator cap taking a crap, but.....
OK, I was able to add some water, and drive it home ( about 1 mile), drove fine no overheating, but when I parked it and turned it off it just poured all over the place. It is real hard to tell where it is coming from, but I now know, it doesnt leak when its started up, or driving but it pours out when you park it and shut it off......any ideas
had something like that happen to me. it turned out to be one of the hoses located at the rear of the engine (behind the tps) had collapsed and started to leak. when the coolent poured out, it came out on the passenger side behind the wheel well. I didnt catch it previously because when the coolant leaked it fell on the exhaust pipe and evaporate. the only clue i really had of a coolant leak was the smell of coolant everytime i floored it on the highway.
hope this helps.........
OK what I have found so far is that the leak is coming from the back (between the engine and the firewall) and left if you are looking at it from the front of the vehicle. Its gotta be around that area...any ideas? :\
