Coolant Everywhere!
Old Oct 7, 2006 | 11:39 AM
mt_goat's Avatar
Cebby's 4runner had a headgasket leak in the back of his 3.0. Sometimes they leak externally. https://www.yotatech.com/forums/f2/10-years-140k-miles-first-stranding-53317/
Old Oct 8, 2006 | 06:12 AM
Tempeboy's Avatar
OK thankx, for everyones, help...upon further inspection it was a hose behind the engine that goes it the firewall it's an easy fix and most importanly easy access..once again THANKS..I love this site.
Old Oct 8, 2006 | 06:28 AM
kiggy74's Avatar
This sounds similar to the problem I'm having. I know I'm losing coolant from this same area. It's not leaking enough to hit the ground, but it's ending up on some part of the exhaust because once the engine warms up it the spillage gets cooked. I'm having trouble locating the leak though.
How were you able to determine the exact location of this leak?
Old Oct 8, 2006 | 10:43 AM
Tempeboy's Avatar
I had my friend drive around the block, and then park and pop the hood with the truck still running, I started looking around the area that I suspected the leakage and had him rev it up a little thats when i noticed the coolant flowing out.
Old Oct 9, 2006 | 09:35 AM
  #25
TNRabbit's Avatar
There are heater hoses on top of the engine behind the plenum and also a little u-shaped hose that is a PITA to get you; you practically have to remove the plenum, but I've heard some folks were able to change it out without removing anything...good luck!
ladybugRC
458
Aug 21, 2020 10:41 AM
LittleUgly
15
Jan 2, 2020 01:30 PM
wberry85
May 17, 2016 05:45 PM
alexcarey
Oct 14, 2015 06:05 PM
kcaudill
Oct 10, 2015 02:39 PM
