Help Asap!!!
Old Sep 22, 2006 | 04:59 AM
mburg28's Avatar
Help Asap!!!
Yesterday when dismantling the cylinder heads on my 89 3vze, I snapped a electrical connector on the water by-pass oulet.
When looking at the engine from the front of the truck its the connector on the right side of the by pass outlet, the smaller of the two connectors there. It's not the ground connector either.
I have searched around and don't know what this part is called. Does anyone know this part off hand? Also if you know of a website that would have mircofische, that would be a big help.
Thanks
Mike
Old Sep 22, 2006 | 05:16 AM
mt_goat's Avatar
Got any pics? Here's the 93 FSM (it will be similar):
http://personal.utulsa.edu/~nathan-b...fsm/index.html
Old Sep 22, 2006 | 05:28 AM
mburg28's Avatar
Might be able to get a actually photo up sometime tonight. In the meantime the arrow points to the specific part
Thanks...
Old Sep 22, 2006 | 06:03 AM
Veladarius's Avatar
The one closest to the arrow is the EFI Temp Sensor (in the FSM it is the ECT Sensor). It is not the regular temp sensor! I just replaced mine and it took the dealer 3 weeks to get me the correct one. The one I got has a grey top to it and was about $60. The other sensors there are the Temp Sensor (farther to the right, round top) and the Cold Start Time Switch (on the left of the hose).
Old Sep 22, 2006 | 06:25 AM
snap-on's Avatar
see water bypass parts for a 1000 alex
https://www.yotatech.com/forums/f116/name-those-water-bypass-parts-74247/
note in that pic the waterbypass is shown "backwards" the TTV (the thing with the busted nipple) is acutally on the pass side of thet truck.
it should also be noted that there are at least 3 diffrent versions of the water-by-pass outlet that i know of. (with diffrent sensors on it and layout)
but they all esentally do the same thing... the changes were just do to diffrent sensors used throughout the years...
Old Sep 22, 2006 | 06:29 AM
mburg28's Avatar
Beautiful...
Thanks
Old Sep 22, 2006 | 07:34 AM
04 Rocko Taco's Avatar
Yotatech to the rescue again!!
MadMax48
Mar 3, 2020 10:33 AM
ToyotaMD
Aug 17, 2018 10:16 PM
