- Lexus V-8 in 2nd gen
- Fan Clutch Replacement?
- Power Steering Sensor?
- Powertrax lock right locker, any good?
- Headlamp housing replacement
- V8 swap
- V6 Rough Idle
- Power Steering Pump Rebuild Question....
- 89 Yota Finally Beat Me....
- Cornor Light Question
- a good use for a jeep!
- Best bang for your buck-suspension or body lift?
- Head Gasket Spray Adhesive?
- 88 pickup won't turn over
- Good mechanics in DFW?
- Valve guides or Oil rings going on 120k mi 22RE?!
- Bigger Than Stock Oil Filter
- trobleshoot oil pressure gauge
- Mostly after long drive 1st start is cold choking
- oil additives, good, bad?
- L trim removal on 1st gen runner?
- Fuel Injector End Cap
- Pulling right?
- Rear Window ?
- what is this part called?
- aftermarket springs
- 32's and 4.88 Gears?
- Vibration
- Replacing front/rear suspension and want a little confidence
- revise post....OME 860 pictures needed.
- OME Suspension shocks do not fit!
- So I Rebuilt my Carb
- Engines comming out for replacement. what else should I take care of ?
- Flooded 3.0 Rebuil Hmmm....
- 3vze performance
- Double Cardan centering ball
- Cat or no cat?
- What fits? Blew up two trannies
- Cut of my muffler, Should I keep i off?
- 350/v8/sbc swap.
- radiator relocator 94 pickup w/3" lift ?
- Side mirror replacement question
- so....I dropped the oil pan today...
- Roof Rack 86 4runner
- Need 89 oil pressure gauge and sender
- 22re INTAKE full of gas
- Tech Write up - Rear spring install - 2nd Gen 4Runner
- Correct Idle Setting Procedure
- charcoal canister
- oil filter relocation kit for the 22re
- Tapping a wire for backup light, where?
- What Year Rear Windows Will Work In My 89?
- 90-95 oil gauge anyone?
- Vacuum Lines are amazing
- Speedo Cable replacement, Help!
- Last chance to talk me out of puchasing a new engine!
- 22RE Starter Removal Trouble
- New Toy Owner and rear locker question
- Eibach springs installed (pics)
- 3vze cam and valve question
- Trouble closing hood
- Power Issues
- Advice for EFI codes
- Torque Spec for Knock Sensor??
- cruse control 91 pickup 22re
- tranny solenoid problems?
- 22re initial startup problem (very long)
- Ciger. lighter plug/ DC plug?
- 1986 22re Intermittent B.s.
- Heater lever wont go past half (90 4rn)
- My $750 '86 4Runner
- 3.0 idle problems
- 22re swap 87 22re in a 90 pickup
- 95 rear end
- wierd front end noise
- suspension
- How Much Would You Pay For...?
- 3.0 oil leak!
- Anyone tried this Fiberglass approach?
- Cat is poopin the bed need new exhaust
- Small Lift on a 92' 2WD Pickup
- valve cover gasket...
- 1991 2Dr SR5 4x4 5spd
- front end making some horrific nioses in 4wd
- Drain holes in frame ???
- Anyone done a VW Diesel swap?
- Need good clutch removal/install write-up
- Any suggestions for removing gaskets?
- 22r coil issues
- 22re head replacement - lessons learned
- little bit of water almost kills truck
- One quick question
- Gun Rack For Yer 4Runner?
- Bumper
- gas mileage question
- 4rner gauge cluster removal ?'s
- 95 3.0 code 25 cel
- weight of an 89 pickup
- 94 pickup 6cyl / 4cyl banjo housing swap questions.
- ?-Replacing the clutch cylinders
- Battery prob. 4Runner wont start!
- How much can an ifs truck/runner do?
- Best rust neutralizer, Opinions welcome
- Front Diff Fluid
- steering play adj...
- Hesitation Problem When Cold
- lifting rear of truck
- installed my clutch today...
- Yukon Gears broke But why!!
- short throw shifter for 90 Pickup?
- 1uz-e transfer
- 92 4runner speed sensor
- Grinding from 3rd to 2nd gear
- 92 4runner rear glass motor
- What RPM
- Plug for the alternator
- Opinions needed: Weasy vs. EngineBuilder cams
- Early 22RE hard start
- Need help with speedo correction
- Getting new tires
- Horrible noise from.... Gauges?!?!? (video inside)
- Who's hubs break the most -
- What is this sensor?!
- 22RTE/22RE hybrid running.
- Interior Colors
- not even a week old & motor's blown.
- Topless?
- 94 4runner 3vze missing under load
- 1st gen seat cable fix
- oil pump or oil gauge out?
- spark plugs
- 89 4runner issu
- Automatic ECU into Manual
- Rear Window Question
- Blown Head Gasket or Something Else?
- 4pin trailer harness
- todays snow run!
- Oil pump out?
- BJ spacers and lift kit.
- Are auto trannies as reliable as sticks?
- vacuum hose layout
- slipped t-chain
- does 22r head = 22re head
- 86 4Runner won't start!
- Front turn signal problem
- Fluctuating Idle problem 90 V6
- Need new gas lift shocks on windows or hood?
- please, not the cpu
- 86 22r Starting Problem
- tail light relay??
- difference between sfa and ifs hubs
- how many miles are too many for a 4runner?
- Valve adjustment on Rebuild
- Just more 4.3 swap questions
- tires size with 4 " lift
- Can't get my upper bumpstops off
- 92 or 94?
- Optima Battery
- jumpy speedometer
- diesel swap?
- Speed Sensor Questions
- 3.0 and 22RE redline
- Damn exhaust leak at the header flange.
- 268 Cam for 22RE, did it do much for you?
- death wobble@55mph
- Slap then oil leak!!!
- Engnbldr Street RV head
- Electric fan temp probe
- Does this sound like rockers?
- Transfer case ???
- HO alternator question
- 93 pickup turn signal problem
- Head Bolt size on the 3.0L V6
- toyota hilux??
- Lil Triangle Windows
- Reman or rebuild ill 3VZE?
- Clutch diagnosis?
- 92 4runner hot error code 14
- Promar Engine Rebuilders
- Rev/tach problem
- Rear end Breather mod for 88 pickup
- auto trans touble
- 3.4 conversion and CA Smog tests
- Blown HG and 226k motor
- 22re Coolant problem
- Power Steering Box Rebuild
- motor oil question
- Do I need a new throttle body?
- Albertans...need 1st Gen rollbar
- 32x12.5's on 15x10 inch wheels??
- 92 22re Ac?
- rough idle at start
- Speedometer stopped working
- Instrument Cluster Wiring
- Idle adjustment
- Replacing knock sensor...
- 22R and power steering?
- rear end whining somewhat
- How to go about cleaning AFM?
- help with Knock Sensor Wire
- 22ret Pistons
- Back window 91 runner, new solutions anyone?
- 1987 turbo 4runner
- stumble 3VZ-E
- Heater fan doesnt work on lowest setting.
- 2nd Gen. Mirror Disassembly?
- new 4wd and 2wd grille's?
- manual locking hubs HELP!
- junkyard interior resto...
- rough idle, poor mileage
- Alternator problem... (H.O. Advise)
- Gear Driven "Shift on the Fly"
- Helpful Hint for Tree Dents :)
- sas with '80 axle, more questions.
- Engine code help!?
- head gasket leak on outside....???
- Replacing headlight adjustment plastic tabs
- gear driven transfer case on v6?
- '91 V6 PickUp - Start Problems
- 22r Hoses
- 93-4WD won't start
- Upgrades/mods/maint. to do while Heads are off
- TO Bearing
- seafoam treatment question
- Charge Light/ Oil Light
- Temperature gauge dead on a 90 runner
- 1992 22RE 4x4 pickup headlight wiring.
- dead 4runner
- Rgh idle, pr mlg,fuel smll in crnkcse, lcks pwr
- Engine stutter/jerk to be death of me
- 94 lift kit
- will a XD9000I fit into an ARB bumper?
- Reubuilt or Remanufactured 3VZE?
- 22RE vs 22RET shortblock differences?
- Head Gasket on 87
- Rear window position sensor?
- Can anybody else pull the key out with engine running?
- husky liners
- 4x4 engages but no 4x4
- 87 4x4 PU
- another fuel injector question
- 94 4runner auto transmission
- body lift question
- Hello and thank you for info
- Got The 89 Yota Going, But Still Issues
- Cruise Control Fixed on 2cnd gen
- torque converter problems?
- NO heat or ac? blower motor?
- Valve Adjustment Confusion
- Hesitation/stalling during acceleration
