22re Coolant problem
Old Dec 7, 2006 | 10:43 AM
RustBucket's Avatar
Hey guys,
I drove back to school from the mall today, stopped at the front of the building for a few minutes to let some people out, and then as I pulled away I heard a strange noise for a second from the front drivers side of the engine compartment. I didn't think anything of it and I drove the 1/8 mile to where I park, and got out and noticed wetness all around the drivers side front suspension and stuff, even on the mudflap. It was not water, and I determined it was coolant. I opened the coolant overfill reservoir and it was full to the brim and the little overflow hose had splash marks out of it.
I am not in the habit of overfilling my coolant system... any idea why so much coolant ejected out of the overflow tank?
Old Dec 7, 2006 | 06:33 PM
spudrunner's Avatar
thermostat stuck closed?
Old Dec 7, 2006 | 06:37 PM
Elton's Avatar
sounds like it started over heating could be a t-stat wich are very easy to change just make sure you get the dual staged ones from the dealer
Old Dec 7, 2006 | 06:46 PM
drew303's Avatar
I'd replace the Thermostat and the radiator cap. All the books will tell you to test them but they're so damn cheap just get new ones.
T-stat replacement is probably the easiest (besides the cap ) maintnence you'll ever do to a yota =)
Old Dec 8, 2006 | 10:09 PM
RustBucket's Avatar
Hmm, it never gave me a sign of overheating... And the t-stat is brand new! It is one with the little bypass valve as well.
The radiator cap, eh? Think it could be leaking?
Old Dec 8, 2006 | 10:44 PM
drew303's Avatar
buy a new cap
Old Dec 8, 2006 | 10:46 PM
salad_man's Avatar
Also if the radiator cap dosent have a good seal or dosent close tight enough it might send fluid to the over flow. I have an 88 that has done that before...
Old Dec 15, 2006 | 05:22 AM
toyman2's Avatar
if you lose a head gasket it will pressure the cooling system
Sleaker
Aug 26, 2020 06:03 AM
Colington
Mar 8, 2020 09:51 AM
ryerye13
Jul 14, 2015 08:27 AM
Poncho0206
Jul 10, 2015 06:21 PM
Avenged
Jul 9, 2015 07:55 AM
