Optima Battery
Old Dec 8, 2006 | 08:51 AM
Red3.slow's Avatar
Optima Battery
Anything else I need to purchase when getting an optima yellow or red top for my 95' 4runner besides the battery itself. Also which one would you guys prefer yellow or red top.
Old Dec 8, 2006 | 08:54 AM
rdlsz24's Avatar
Make sure that the battery your buying matches what type of connections you have, like posts, flush mount, etc. You also might want to at least change the ends of your lines if they are crusty and corroded.
As far as which to get, check this out: http://www.optimabatteries.com/publi...utomotive.html
Old Dec 8, 2006 | 08:57 AM
04 Rocko Taco's Avatar
Get you a premium set of battery cables.
If your gonna go Optima, might as well change out your terminals, and might even consider doing the power wire mod, run 4 gauge from your battery to your fuse box instad of what is there now.
Old Dec 8, 2006 | 09:00 AM
Red3.slow's Avatar
Yeah I was thinking about doing that as well, at least with the ground. Is it difficult to do on the fuse box?
Old Dec 8, 2006 | 09:02 AM
Elvota's Avatar
There is a spacer that goes under the Optima to make up for height. Usually comes with the battery, but make sure one is included.
You can make you own if need be, but if you don't the battery will sit low and you'll have to mod the factory hold down bracket in some way.
Old Dec 8, 2006 | 09:03 AM
not really, I had it done on my Mx6. I keep saying Im gonna do ti on the taco, to lazy though.
Old Dec 8, 2006 | 09:19 AM
da_bigg_wigg's Avatar
Creepy. I was just thinking about the same thing...
Old Dec 8, 2006 | 11:22 AM
drunberg's Avatar
I'm on my 2nd Optima Red Top. It will mount right into the tray with no issues, provided of course your last battery did not corrode the battery area.
smilen724
13
Nov 8, 2015 04:11 PM
Chicken12
Oct 14, 2015 03:54 PM
Gone Fission
Oct 7, 2015 12:42 PM
mreagen
Oct 5, 2015 04:27 PM
JPV
Sep 28, 2015 03:15 PM
