Drain holes in frame ???
Old Dec 13, 2006 | 11:49 AM
swerks's Avatar
Question Drain holes in frame ???
I was told today that I might want to drill extra drain holes in to my frame. because of its box construction it will hold water. any body doing this??? I have not heard this advice before.
Old Dec 13, 2006 | 11:58 AM
CJM's Avatar
CJM
Unless there are already holes in it, how would water get in? Water will ge in through holes you drill to drain it too.
Old Dec 13, 2006 | 01:13 PM
da_bigg_wigg's Avatar
The last thing you need is more holes for crap to get into. You also have to worry about rust proofing. Drilling holes in frames for no reason doesn't seem like a good idea to me...
Old Dec 13, 2006 | 01:21 PM
all_terrain17's Avatar
Don't bother. If that was a problem, hopefully Toyota would have addressed it. Like the others have said you don't need anymore holes in your frame...why weaken the frame to keep it from weakening?
Old Dec 13, 2006 | 02:41 PM
jaymo's Avatar
I agree no need for more..
But be careful of the tube crossmember behind the tank. Water must get in there and sit, cause mine rotted from the inside out. Im replacing it this week.
Old Dec 13, 2006 | 02:52 PM
CyMoN's Avatar
I spray mine out with a high pressure washer every few months
Old Dec 13, 2006 | 03:01 PM
Sonofmayhem's Avatar
One, deep water, two carwash, and the water will drain right out wont it.
I would do one by the rear spring hanger mount, the only issue is rust proofing you could paint it then get a brush and jam it in there to get the top.
Strength can be dealt with holes of the right size add surface area. hence more area to spread the weight.
young buck
18
Aug 27, 2018 02:40 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
yourrealdad
Jul 21, 2015 11:13 AM
kcaudill
Jul 20, 2015 12:06 PM
daddio
Jul 18, 2015 10:20 AM
