4pin trailer harness
Old Dec 9, 2006 | 09:07 PM
hirsche23's Avatar
Has anybody hooked up a 4 pin trailer light harness to a 1st gen 4runner?If so how is it done since the lights are all on different circuits?Is there an adapter-I've checked a couple of places with no luck.Any help is needed so I can wire this myself.Thanks
Old Dec 10, 2006 | 06:25 AM
Yoda's Avatar
My son bought a kit at NAPA. It plugged into the harness of the truck (behind each tail light), connect a ground wire and done. There was no cutting of the factory harness. His is a 85 pickup, should be the same as your connectors.
It has the adapter built into the harness. It was something like $50 USD.
Old Dec 10, 2006 | 07:43 AM
hirsche23's Avatar
Thanks,I never did try Napa i guess it's the next stop.
Old Dec 10, 2006 | 04:50 PM
RD1970's Avatar
all you need is a diode box to seperate the turn signal. I got mine from draw-tite
Old Dec 11, 2006 | 06:42 PM
trythis's Avatar
the napa deal is really easy, and has the diode thing.
Old Dec 11, 2006 | 07:06 PM
toy283's Avatar
To make the truck connection work on a 4Runner will require a bit of drilling, cutting & splicing. On the trucks, the back of the taillight is exposed, on the 4Runner it is enclosed inside sheet metal. You will need to drill a couple holes for the wires and then cut off the connectors, feed the wires through the holes and splice them back together. This is what I had to do for my '85.
91yotapup
3.4 Swaps
Mar 5, 2019 10:41 AM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
Cycles
Sep 29, 2015 06:37 AM
tshort48
Sep 27, 2015 01:04 PM
Toys4parts
Sep 26, 2015 01:56 PM
