Early 22RE hard start
Old Dec 11, 2006 | 05:20 AM
refugio's Avatar
Greetings:All
Couldnt find help in FAQs but Im sure this is a common problem: '86 4X4 P.U. hard to start 1st time every day(cold/wet/dry/warm) Cranks over fine. Will always start with a little help from a spray can, but thats not putting any longevity in my 100K engine I know.. The problem started out as easy start, but no fast idle when cold..gradually getting worse until now it wont start without liquid help.. Tried a different(known good) cold start valve- no difference. Its getting to be the rainy season and I guess its time to ACTUALLY FIX IT!!! Thanks in advance Refugio Red
Old Dec 11, 2006 | 05:58 AM
rdlsz24's Avatar
Check out this thread: https://www.yotatech.com/forums/show...hlight=rdlsz24
Rob
Old Dec 11, 2006 | 06:38 AM
refugio's Avatar
Thanks for good post & pix
Pictures do the trick, tks
Old Dec 12, 2006 | 06:43 PM
refugio's Avatar
22 RE hard start Follow-up
Rob, I just had another thought(Thats 2 this year already!!) My "theft deterrent" is a push-button hidden starter switch under dash. Since the Cold Start Injector only fires when starter is engaged & I had bypassed the original solenoid wire from key switch...Follow my drift? Is circuit completed only when the key switch is in start position?? Red
Old Dec 13, 2006 | 06:11 AM
rdlsz24's Avatar
Hmm sounds like it could be a possible culprit. I don't know the wiring on these trucks good enough to give you a positive answer, though. I'm sure some people on here know. Is there any way you could temporarily undo your push button switch to test your thought?
Rob
Old Dec 13, 2006 | 05:41 PM
refugio's Avatar
OK Got it-it was the lack of connection from key switch to Cold Start Injector. It didnt act up til weather changed.. Just put a "T" connector on solenoid tab-
1 side of "T" for original solenoid wire-1 side to push button-Problem solved-thanks for help...Red
Old Dec 14, 2006 | 06:03 AM
rdlsz24's Avatar
Glad you got it figured out. Mine was the same way when I disconnected it to install an aftermarket gauge. I didn't have a problem till summer turned to fall and it started getting colder out.
Rob
Ichneumon
Sep 27, 2015 04:21 PM
94 Newbie
Jul 6, 2015 04:23 AM
CJ94yota
Jul 3, 2015 10:14 PM
jmc88runner
Jun 18, 2015 03:39 PM
