Any suggestions for removing gaskets?
Old Dec 13, 2006 | 06:46 AM
rdlsz24's Avatar
This is for removing engine gaskets in general, but my particular problem right now is with getting my blown head gasket off of the block. I have been trying the putty knife trick, but it doesn't seem sharp enough to do the job. What tools or chemicals do you guys recommend, and do I need to be careful of damaging the block?
Rob
Old Dec 13, 2006 | 06:52 AM
MMA_Alex's Avatar
usually a gasket scraper is enough to get it off if you work at it. You can try scotch brite pads, or sandpaper if you're careful to not damage the mating surfaces.
Old Dec 13, 2006 | 07:11 AM
the_4runnin'_beast's Avatar
If you are REAL careful you could use an abrasive pad on a little air-powered die grinder. You need to be incredibly careful not to let it dig into the metal. You need very light stokes.
Old Dec 13, 2006 | 07:26 AM
maxpower_hd's Avatar
That's what I use. You don't have to be quite as careful on the block if it is a cast iron block since it does not mar as easily as the aluminum on the head. The key is to only take off the gasket and not the metal. they also have different pads. Some are more course than others.
Old Dec 13, 2006 | 07:33 AM
ewong's Avatar
I use a plexiglass ski wax scraper.
On the cast iron block I used some chemical gasket remove (permatex) and a razor blad. Its kind hard to gouge the cast iron block, but dont try to either.
Old Dec 13, 2006 | 08:36 AM
spudrunner's Avatar
I seem to remember some sort of gasket remover spray or brush on stuff from the local auto parts store. Worked pretty good too!
Old Dec 13, 2006 | 08:51 AM
Ringmaster's Avatar
Chemical gasket remover, spray some on, let it sit for 20 minutes, scrape it off, and apply another coat of remover scrape it again.
Gaskets get very hard with age, letting the chemical soak on them a time or two works wonders.
Old Dec 13, 2006 | 08:57 AM
4runnerx3's Avatar
Go to NAPA and get a can of gasket remover. Spray it on and the stuck on gasket turns to goo.
Old Dec 13, 2006 | 09:18 AM
881stGenRunner's Avatar
Just-intime tool works good for me. (orange scraper)
Old Dec 13, 2006 | 09:44 AM
Dan90SR5's Avatar
Their are these yellow pads with a bunck of long studs on it. You can get them at Lowe/Home Depot. They mount onto an air tool and rotate. Put clothes in your cylinders. There is no risk of damage to your block using these. When done, pull the clothes out, careful to get all or as much dust and gasket material out as you can. What you can't get out, use a shop vac to suck it out.
This is what we used in the Coast Guard and it's the best thing that I've seen to do the job. Good for rust too.
Old Dec 13, 2006 | 11:40 AM
surf4runner's Avatar
i sharpened a putty knife, and w/the gasket goo stuff, makes the job a breeze
Old Dec 13, 2006 | 12:31 PM
isaac338's Avatar
aren't those called flap brushes?
Old Dec 13, 2006 | 03:55 PM
Dan90SR5's Avatar
I can't remember what they're called, but they work great. They're yellow and made out of plastic.....the whole thing, bristles and all.
These aren't those wheels with the sand paper flaps if that's what you're thinking.
Either way, the yellow plastic wheels with the bristle are the best thing I've used to rmove gaskets. Give it a try sometime if you see some out in the store.
Old Dec 14, 2006 | 08:50 AM
Bumpin' Yota's Avatar
HOLY CRAP!! That permatex gasket remover sold by NAPA freakin WORKS!!
I have a few trouble spots on my 3vze deck that were being stubborn, this stuff, plus a sharp, stiff paint scraper just wizzed it off!!! Aside from DEVOURING anything not metal, it also penetrates carbon build up VERY well! Now my valve reliefs look squeeky clean!
Old Dec 14, 2006 | 09:08 AM
Those things do work awsomely well. I totally forgot about those. We use them at our shop.
Old Dec 14, 2006 | 09:44 AM
this thread is worthless without pics!!!! lol
Old Dec 16, 2006 | 06:07 PM
Dan90SR5's Avatar
I'll see if I can't find some tomorrow and post some pics. I don't have any in the garage right now.
Old Dec 16, 2006 | 06:30 PM
dirtoyboy's Avatar
gasket remover and a razor blade
cars-guy
Aug 16, 2020 06:59 AM
Sep 4, 2015 09:27 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
irritech
Jul 27, 2015 05:15 PM
Snort
Jul 9, 2015 03:58 PM
