88 pickup won't turn over
Old Dec 19, 2006 | 08:55 AM
Shaymer's Avatar
Got an 88 Toyota 4x4. Took it wheeling and it wouldn't start after. Noticed that the main power cable (white) into the positive terminal ripped off when the battery started flopping around. Re-installed that and it still wouldn't start. Tried jumping it, still wouldn't start. Just replaced the starter and it still wouldn't start. I can pop start it and it runs fine. Checked all the fuses and they seem fine, but there is a 'RELAY' fuse in the box which the white power wire goes to that I cannot check. The fuse is maroon in color, 12v, and says 'toyota' on the side. Wondering if that's it.[/LIST]
The engine will not turn over. It will just 'click' once. Any other ideas.
Thanks,
Old Dec 19, 2006 | 02:50 PM
Elton's Avatar
welcome to yotatech .... i would look over all the battery cables real good
Old Dec 19, 2006 | 03:08 PM
Th3duke's Avatar
Check out 4Crawler's site, and check to see if you have power going to the starter (the big one from the battery) and the little one going to the solenoid.
Roger's jig really works good... here's a pic of it.
Highly recommend you have a look at Rogers site. http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
Regency
20
Jan 3, 2020 07:43 PM
Cesarl74
Apr 23, 2016 06:07 PM
Jmiller1023
23
Aug 6, 2015 07:03 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
aciorba23
Jun 29, 2015 04:18 PM
