95 rear end
Old Dec 14, 2006 | 08:17 AM
EineZweiDreiVier's Avatar
95 rear end
how do you access the speakers in the back of a 95 4runner? I can get at the ones that are roof-ward, but not the ones on pillars or the ones near the cargo compartments.
Old Dec 14, 2006 | 03:32 PM
AH64ID's Avatar
I dont know for sure on yours but mine only had 4 speakers total, 2 in the front and 2 in the side of the back... there were speaker slots in the top by the cargo light, but no speakers... The rear ones are pretty easy to get to thou... pry the platic by the cargo light off with a slotted screwdriver, then unplug the light and set aside. Then unscrew the plastic piece between the carpet and the tailgate. Then using a 14mm wrench unbolt the upper seatbelt mount for both outboard back seats. Then pry the side plastic away, it just clips in like the cargo light piece.. .pretty simple...
Old Dec 15, 2006 | 05:00 AM
Really??? I took that piece down a few months back but I never noticed if there were speakers there or not.
I will try doing what you said tomorrow... sounds easy enough, but its hard to do when you get home well after dark.
Thanks!
Old Dec 15, 2006 | 01:33 PM
AH64ID's Avatar
let me know what you find
Old Dec 15, 2006 | 02:09 PM
95RunnerSR5's Avatar
there are spots for tweeters and such but no actual speakers to speak of
Old Dec 15, 2006 | 02:10 PM
Elvota's Avatar
I think the speaker grills you are referring are actually vents of sort. I always thought they had something to do with the window gaskets in that area. Look close at the tail edge of the large fixed window from the outside and you will see the gasket is vented.
Anyway, my '91 doesn't have speakers either and I don't even think you have the depth in that area to mount them.
Old Dec 15, 2006 | 02:11 PM
da_bigg_wigg's Avatar
I have some (disconnected) factory tweeters up there. It's not big enough to put anything decent in there in my opinion.
Old Dec 17, 2006 | 08:54 AM
no, there are speakers back there, i found them after an hour of yanking those pop clips out, they worked until I got my new head unit put in... so I guess I am going to bring it back to where I got it done and see if they connected something wrong. Also, I bought new speakers to put in and they did not fit. grrrrrrrr
Old Dec 17, 2006 | 05:22 PM
Elvota's Avatar
Maybe being a 91' the factory didn't install them in mine. Also, looking back at your post I am thinking I might be visualizing a different part of the truck. My comments were in reference to the grills located at the upper corners of the fixed windows, where the side panel curves to the headliner.
But, I did buy the truck used, so who knows how many things had been removed or added before I got a hold of it.
Old Dec 17, 2006 | 08:28 PM
Tofer's Avatar
Sponsor
my 94 has factory tweaters in the rear...
Old Dec 18, 2006 | 02:33 AM
I realized which ones you were talking about this morning as I was driving to work... only after pulling off the plastic panel in the back of the truck.
the1998sr5
15
Jul 14, 2020 08:35 PM
Daneums
Aug 20, 2015 05:36 AM
rondogracing
Jul 14, 2015 07:00 PM
hangtown88toy
Jul 10, 2015 02:33 PM
akaphilly
Jul 9, 2015 02:18 PM
