Rear Window ?
Old Dec 17, 2006 | 06:13 PM
2RUNNERS's Avatar
Rear Window ?
I have a tail light out and need it replaced....but I can't open my back window it just stoped wprking...is there a way to get the tail gate open when this happens... it's a 92 runner. thanks guys.
Old Dec 17, 2006 | 06:16 PM
Elton's Avatar
climb over the back seat
Old Dec 17, 2006 | 06:18 PM
2RUNNERS's Avatar
Ok that's great...so now how do I chang the burnt out tail light..
Old Dec 17, 2006 | 06:21 PM
Elton's Avatar
just unbolt it and pull it off
Old Dec 17, 2006 | 06:26 PM
2RUNNERS's Avatar
what do you mean...unbolt what and how ?
Old Dec 17, 2006 | 06:27 PM
Elton's Avatar
when you get the tail gate open look at it should see 2 bolts
Old Dec 17, 2006 | 06:31 PM
2RUNNERS's Avatar
That's my problem I can't get the gate open because the window is not working..
Old Dec 17, 2006 | 06:32 PM
4Crawler's Avatar
Might try getting the rear window opeing, usually something simple:
http://www.4crawler.com/4x4/CheapTri...arWindow.shtml
Old Dec 17, 2006 | 06:33 PM
Elton's Avatar
can open it from the inside
Old Dec 17, 2006 | 09:14 PM
reggie 00's Avatar
What have you checked?
have you tried to open it with the key?
my switch just went out, Marko helped me figure it out last weekend, we basically took the switch out and jumped the plug to make the window go up and down.
Or is your motor shot?
motor is the same as the power window motor.
Good luck
Old Dec 17, 2006 | 09:58 PM
Greg_Canada's Avatar
use a 12v battery and hook the cables directly to the motor to bring it down.
Old Dec 17, 2006 | 10:06 PM
reggie 00's Avatar
It'll run on a drill battery, i have used charged up 9.6 batteries to test, move ect.
Old Dec 17, 2006 | 10:33 PM
4x4Lamm's Avatar
Dude, he has a second gen. It is VERY different from yours in the back. To open the tail-gate and get to bolts that hold the taillight in place you MUST lower the rear power window.
Lamm
Old Dec 17, 2006 | 10:52 PM
Numbchux's Avatar
I know the 1st gen ones have a sensor on the wiper so if the wiper isn't all the way up, it won't let the window roll down....it may be worth a try.
Old Dec 19, 2006 | 10:00 PM
steelydan's Avatar
Here's what I did when facing same poblem:
Climbed in back and removed carpeted panel. Unplugged blue color plug with power window leads. Red and green wire inside plug. Hooked 1 to positive side of battery and Touched Negative to the other. If window doesn't go down, reverse wires. You can use truck battery or drag one in the back with you. I used long leads and truck battery. Once window is down and tailgate open you can remove control board behind plastic panel to the rear of the drivers side storage bin. I pulled mine out and soldered a 2 pole single throw centre off switch to the green and red wire on the board. Ran it up under dash. Ordered a new control board from a wrecker. Switch will work till new board arrives.
Old Jan 6, 2007 | 10:26 PM
Heh i actually use the 7.2v battery from my R/C car....
Old Jan 6, 2007 | 10:45 PM
TOYZILLA's Avatar
Back Window Stuck
Hello have you checked to see if your window lock in the middle of the console isn't on the loc. also make sure the tailgate is fully closed if all that is ok then you'll have to take the left side rear panel and chase the wires for the motor see if you cant get power to lower window down."check fuses also" hope one of these work. good luck if you need any more help just pm me i'll try to help further. BEAR "TOYZILLA"
Old Jan 20, 2007 | 10:45 PM
just a 22re's Avatar
i can open my rear tail gate with the window up but o a much better nonbeater you might not get away with that but just stick a screew driver in the tail gate and pop open the latch
Old Jan 20, 2007 | 10:46 PM
but please watch the window it might brake on a better truck then mine
Old Mar 14, 2007 | 04:10 PM
jfk4runner's Avatar
how much is the computer box that rolls down the back window? i have a 1988 and the back window wont go down!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
HELP
