rear end whining somewhat
Old Dec 6, 2006 | 03:14 PM
scenarioL113's Avatar
I had a pin hole in the top of my rear end, which only leaked on the highway.
I noticed a slight howl on the backlash and when I investigated I unfortunately found I had very little diff oile left. It really is not that bad but more of a nuisance.
I know the damage is done but is there any additive or something some one could reccomend to help the situation.
I heard maybe something from Lukas oil.
I temporarily repaired the hole with JB Weld and is holding great, I will braze or weld it next month. I drained what was left of the diff oil and then filled it with Castrol Full Synthetic gear oil.
I have another 3rd member I can put in but it is a different ratio than what I have. I will do it eventually but I am not in the mood to change the front end so it will have to wait until the spring.
Old Dec 6, 2006 | 03:24 PM
BC Rider's Avatar
some guys have told me that molyslip worked for them and quitened the howl.
While the idea makes some sense, it did not work for me and I ended up replacing the 3rdmember. Probably depends on which part is causing the howl.
Old Dec 6, 2006 | 07:42 PM
MMA_Alex's Avatar
were there any metal shavings in the gear oil you had left in it? If so it may already be too late.
You can try a mix of lucas and regular gear oil if you like.
No sense in wasting money on synth unless you get the synth lucas, which is like $20something a quart.
Lucas recomends a 50/50 mix of lucas and gear oil, and with that you may be able to hold off the inevitable for the time being.
Old Dec 6, 2006 | 07:46 PM
toyota_mdt_tech's Avatar
I suspect the gearset is galled. The only fix is new gears. A bad bearing usually is a little riugher. Pinion bearings do fail on this also.
Old Dec 6, 2006 | 08:00 PM
Yes there were shavings piled on top of the drainplug. That was the only shavings I saw. Put my finger in the hole and probed a bit and the rest was clean.
I agree the damage is done.
Thanks
Old Dec 6, 2006 | 08:07 PM
Thanks
Small shaving like powder is normal. And even very small peices are OK, But chunks, well...
Old Dec 7, 2006 | 03:57 AM
94Runner4x4's Avatar
i had a whine that was just a whine at first, then it was a jet noise, not good, ruined my tranny cause it caused it to overwork itself, not a good thing. i would recommend putting the new 3rd member in because it only makes everything worse once the whining starts.
Old Dec 8, 2006 | 05:16 AM
leiniesred's Avatar
That BG gear lube additive drops my diff temps 10 degrees F! Synthetic oil drops the temps 3 degrees. The BG stuff comes in a yellow squeeze tube, available at NAPA) Using it during and after break-in may be my secret behind successful 3rd member builds. (+ Zuk's carrier bearing preload tricks)
For maximum run time on the damaged diff, I'd put some of that BG stuff in with a load of high-buck 90W140 synthetic oil and start building a new differential. Gears can howl and whine for a long, long time before they fail. I think you'll find pinion bearing damage on that overheated diff. Might as well build a complete new 3rd at your leisure.
the1998sr5
15
Jul 14, 2020 08:35 PM
Daneums
Aug 20, 2015 05:36 AM
rondogracing
Jul 14, 2015 07:00 PM
hangtown88toy
Jul 10, 2015 02:33 PM
akaphilly
Jul 9, 2015 02:18 PM
