- code 56??
- could disconected fuel injector whire throw code 52
- 1988 Supra alternator in 1993 3vze 4runner?
- fuel pump assembly gone bad!
- strange timing cover leak...
- 1st Gen 4runner: Body Vent Flaps Repair?
- Drivetrain Slipping Under Load
- Cruise Control actuator popping sound
- 92 pickup DIY Long Travel 2wd???
- Ball Joint Spacer Lift and Ruined Lower Ball Joints
- 3s-GTE swap into a 88 sr5 turbo p/u?
- Temperature gauge not reading correctly
- Help with finding a thread
- Weekend project: Rear Leaf Install, Autopal e-codes
- Different Steering Stabalizer mounts?
- 1986 22re battery/wiring harness help.
- Exhaust help
- 89 22re (CA) Vacuum hose missing
- Low rpm miss and code 52 need help
- MAF sensor causing check engine light
- engine from hell!!!
- Axle Wrap: Lifted 94 xcab 4x4
- Is my truck a California model?
- Turn signals in trail gear bumper?
- '89 4Runner from Wyoming
- No power
- Aisin lockers!!!!!!!!!
- Finishing up HG job on '86 Runner.
- 22r fuel system help
- 3vze missing at low revs
- 22re hits wall at about 4500 rpm
- 89 22re starts and immediately dies loud pop every 3rd try??
- Rear Vent SR5 Xtra Cab Sound Deadening Help (w/ Pics)
- 190 HP 3VZE (New Oil Cooler)
- 3vze head swap now wont bust off..
- 22re knocking/rattling video inside.
- Little real time fun - trying to split the Auto Tranny/Engine - leaving tranny in
- transmission id
- Denver CO area people!!
- 22re Turbo Issues
- Finally got me some new Tires
- 3VZE Tachometer issues
- 87 Pickup Light and tun signal problems.
- 3vze coolant hose help
- ac problems scorching here in texas
- 2 qts of oil every 1k miles
- whats a good clutch?
- HELP!! Headlight bucket reassembly 86 pickup
- New guy looking for some advice.
- 88 4runner temp gauge 1/2 way up with no lead on
- Little coolant leak on skid plate... *sigh*
- 1995 4Runner SR5 V6 4WD transmission Speed Sensor Location
- 1988 4Runner Brake Booster Upgrade Issues
- 1991 4Runner Question
- 93' re misfiring/tach boucing intermittent
- battery short caused miss
- 1987 pickup cutting out on acceleration
- 90 4runner not starting after alternator work
- ac wiring question
- need help smoker
- What to do...
- Holes from fender flares fix?
- Oily Advice
- power to coil/ no spark from coil
- 22RE Best/Easiest way to Install
- 90 4runner with 3VZE, starter wont engage, alarm beeps randomly
- Using Coke - Coca~Cola in the water jackets of an engine block.
- Crankshaft help. 94 22RE
- 22RTE Turbo question
- Need some help with tire size
- 22re Detonation Sound
- Head gasket replaced, clicking sound.
- We got a smoker!!!!!
- Paint my top
- Head on, Oil Pan on 22re Timing chain with tons of pics!
- New tailgate -- aftermarket or used?
- 1st Generation Rear Window Relay Refurbishing
- 86 pickup fuel filter ?
- Timing chain grind.......
- 89 toyota pickup bad oil cap
- 1995 Toyota 2WD
- sas
- 87 EFI SR5 4Runner prepurchase advice.
- Seat Belt Retractor - How do you get to it?
- LOTS OF RESISTANCE '90 SR5 (starter??)
- PS Issues due to removal of ABS Actuator
- 22re weak or way it is ?
- 22RE timing chain pictures - how bad is this?
- 88 Pickup - Slider Quetions
- 22R overheating. Losing my mind. Please Help!
- 86 pick up turbo question
- any way to tell if the TC has been replaced?
- Plugging 22r AAP
- 3vze connecting rod replacement
- Clutch sticks to floor in first/reverse
- Side view mirrors?
- Looking for an ecu pin out for a 95 4runner m/t
- Car died while starting...
- Timing question on a crane cam
- Spark Plug Ticking After Changing
- O/D light flashing
- Poly or solid tranmission mounts...
- need help with 95 3.0 ac
- 3vze headers -> installed!
- Total newb question about Abs
- 2nd gen 4Runner rear window sensor/circuit?
- What size vacuum hose?
- 3vze, 4wd oil pan gasket
- I Need Yotatechs Best: 3.0 v6 with miss issue
- 90 5spd swap into a 92 4runner
- im beating a dead horse
- intermittent brakes
- Broken ABS Speed Sensor, need help
- Remove light from A/C switch?
- 1986 Gas Turbo Pickup
- Engine Light Code 21
- 1UZ Hilux diff ratio?
- 2wd on a 4wd Rear ABS Speed Sensor???
- 1990 22re ping 4runner
- Brake pedal very squishy
- Bucking/sputtering
- 3.0 truck missing and stalling
- What all to replace on 3.0 top end ?
- blew a fuel line!!!
- Best way to install power steering??? I need to buy complete power steering
- 1991 3.0 4runner Gas in tail pipe and stalling badly
- IFS steering gearbox leaking
- Got some strange sounds going on.
- dash cluster
- Timing Adjustment Problems
- 1988 toyota 4runer help!, start and runs for 3 sec then dies. completely stranded!!
- Rear wheel bearing failure, replacement.
- my new (old) 22re
- 91 Pickup Power Steering Issue
- Engine & MPG issues compression
- Lost spark on bank 2 help is appreciated.
- 93 22re reving issues
- How to break in a newly rebuilt 3vze
- Slave cylinder help please
- Manual Transmission Removal Question
- Repair, swap, or sell?
- Aux Line on Water Pump and Smell Coolant but no Leak
- Does the knock sensor ground through the block?
- Checking In
- Fuel tank pickup and lines
- Can You tell What goes here.
- new head gasket water straight to oil pan-93 22re
- I need help! Part missing but can't identify it!
- Check engine light code 52
- Sudden auto trans leak after checking fluid level
- Rear axel seal leaking
- Toyota Truck 4Runner Heater AC Face Plate
- cranshaft blew out cylinder block, now what?
- vacuum line missing
- 92 22re lack of power until 3000 rpm
- 22RE Light knock at 12-1300 rpm when warm
- Blocks Vs. Chevy 63's for rear lift
- 5vz head gasket
- 89 4 runner locks up when DRIVING please help
- 1993 pick up sticky gas pedal?
- Need a rear bearing measurement...PLEASE
- 3.4 donor
- Contemplating 5-Speed Swap
- thinking on buying high milleage 93 4x4 v6... bad idea?
- Voltage creeps up to about 16-17 Volts?
- 22RE rebuild: Hard to turn over and slight cylinder scratching
- 1993 4runner ac problems
- 93 Toyota Pickup Running Rough under load
- are all toyota bell housing the same
- Worn alternator brushes (images)
- Auto-to-manual hub swap - missing thrust washer, is this critically bad?
- Braided Stainless Fuel Lines
- 22re head fit on 22r block
- my 1990 3.0 4x4 Toy
- 22re explain how to adjust throttle position sensor
- 89 22re Pickup gutless
- Oil pressure validity...
- Need advice for replacing transmission bearings and seals on '86 4Runner
- Graphics help
- Head gasket job completed, still running like a crippled sloth
- How important are these bolts?
- Wont start after carwash
- ECU ac switch pin
- Body repair panels 93 pickup
- Rear wiper and window
- Question on Timing belt
- New Member with 1989 4Runner
- Weird Noise at 3000rpm<... and ONLY THERE.
- Clutch? Or?
- 94 Pickup 3-VZE starting issues
- Truck jerks and randomly stalls
- Will a 90 rear window regulator fit a 87
- Slave cylinder/clutch release fork
- Breaking in my new 3vze I hear marble sound & rod bearing
- High-beams no worky :(
- Valve noise after a new head...how much is acceptable?
- Setting 22r Air/Fuel
- Google Fu weak; roof & "A" pillar repair
- 1989 Power steering conversion Please help!!!!!!!!!!!
- New from Utah
- Rear brakes won't bleed
- Cold air intake 91 Toyota Pickup
- 87 4runner suspenion
- timing problem?
- '86 2wd pickup - Are my front shocks supposed to look like this?
- '86 2wd pickup - What is Hanging off my Transmission?
- Rotor/bearing installation problem
- Turning corner on Head Gasket replacement
- Front crank Seal fixed but still Leaks Oil
- Heat/AC Fan
- ignition coil resistance
- Body Lift Snag
- Timing chain 22re
- Painting an engine. What scheme did you go with?
- what is this 3.0 vacuum related ... by fuse relay block
- I need some ideas of what kind of lift to do?
- 22re egr malfunction
- Valve cover checklist...
- cable to transmission?
- bilstein 5100 in 94 4runner
- EFI problems I've been trying to chase down
- F-150 Horn Swap Help
- Loud clanking/rattling sound under load
- 1990 4runner issues
- Code 11 TPS
- Need Help... New to the 4Runner life...
- Idling issue
- Late style timing idler bolt. Where to buy?
- Odd Head Gasket leak just started drivers side above the forward most plug
- 87 4runner - Shock Suggestions?
- how do i tell if cold start injector is bad
- Does this sound normal? "Video inside"
- 22re code 26 mixture control continuously rich
- Transmission model number
- Mendocino Nation Forest Trails - *Sorry if this is the wrong section*
- I got my new rebuilt engine 3vze
- Timing vs. MPG Experiment
- 94 4runner 3.0 Knock Sensor
- 22r timing kit
- Fitting bench seats - 86 to 81
- 3vze oil pressure and leak
- 1993 4Runner running on 3 cylinders...HELP
- Doors for my truck
- transmission problems
- 1994 4runner side steps, pics?
- Hilux Corner Lights for Pickup
- Lowering ifs.
- 3zve knocking with video
- Odometer off about 9%, speedo about right?
