ac wiring question
Old May 18, 2013 | 08:24 AM
swampfox's Avatar
ac wiring question
I have a 89 4x4 22re 5spd that has a good working a/c unit,I am thinking about transfering it to my 89 2wd 22r 5spd .The mechanical part should be straight forward ,the part that is concerning me is the wiring . The 2wd is a base model which did not have the plug for the clock, so there is a good chance the wiring may not be there for the a/c. So far my internet searches have not answered my questions.
Will the a/c amplifier work with the 22r setup, also what type of idle up solenoid does the 22r use ? Will the wire to the ignitor work the same with the 22r ? It is hard to find 89 body style in my area for parts ,so it might come down to making the harness or pulling it out of the 4x4.
Old May 18, 2013 | 12:38 PM
wyoming9's Avatar
Red face
I hate to say this the wiring is the easy part
Your going to need to find or cobble together a idle up solenoid for the carb unlike the FI engine you can`t just give it more air.
Been so long I don`t know if I ever saw one.
I think the hardest part is putting in the EVAP Coil are you going with a new coil ??
You need the whole box from the truck with ac.
Old May 18, 2013 | 02:43 PM
swampfox's Avatar
If I go with the swap the plan was to swap the complete unit. The a/c works good except for the broken idle up solenoid.
so far my searches haven't showed a carb solenoid ,and I checked a carb that came from a 87 with air and it is similar to my carb. It could have been replaced at sometime it is hard to say. Years ago I owned a 70 chevy pu with a 250 6cyl that had an after market a/c unit without a idle up solenoid, and it was a problem at times.
the1998sr5
15
Jul 14, 2020 08:35 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
88yodabasket
Jul 13, 2015 01:32 PM
