O/D light flashing
Old May 14, 2013 | 07:53 PM
zonian73's Avatar
O/D light flashing
My 95 4Runner automatic V6 4X4 often will not go into 1st and 2nd gear and then the O/D light starts flashing. I don't believe that the transmission is slipping because when I manually place it in L (low gear) it takes off just fine. Any help, please?
Old May 14, 2013 | 08:17 PM
justin_4runner's Avatar
u can do the jumper like u do when checking the check engine light and the o/d light will blink and count like u do with the check engine light. to let u what code ur getting then we can help more
Old May 15, 2013 | 12:31 AM
Co_94_PU's Avatar
Retrieve the diagnostic code(see HERE), and perform the manual shift testing (see HERE).
That might be the wrong transmission, but they are all similar, the others can be found HERE
Old May 15, 2013 | 03:07 AM
zonian73's Avatar
Thank you for your help. I'll use these troubleshooting steps.
Old May 16, 2013 | 10:22 PM
MudRunner92's Avatar
same thing happened in my 93. i cant exactly recall what the code means but its nothing big to worry abt. it cost me 100 bucks to have someone do it
Old Oct 19, 2013 | 05:14 PM
amk3rd's Avatar
continuing the first posters question.
hi, i have 94 3.0 4x4. having same issues as the Zonian73. I can shift manually and get all the gears but wont go in D until im up to speed. I followed all the following posts and got a 62code. showing that its the #1 solenoid. However Im a bit confused when looking at the manual shift test graph. Is that supposed to be while moving to locate the shifter position and the corresponding correct gear? if so all is well with mine. what i am finding is that when at speed on the highway, my O/D button doesnt effect the gear change at all. the light go solid on dash but no kick down in gears. Also could the adjustment of the throttle cable effect this at all? Im not sure what the next step is. replace the solenoid? is that costly and what does the part and labor usually run.
thanks in advance for your help
Old Oct 19, 2013 | 06:12 PM
Luvmeye22re's Avatar
Replace all the transmission selenoids while you are in there. Mine needs it as well It only happens here and there, more when it's cold outside. Usually when I shift it into first and go through second then back into drive it will quit with the antics for the rest of the drive.
Old Oct 19, 2013 | 07:29 PM
zonian73's Avatar
After replacing the solenoid the problem was still happening. I found that it was the wiring around the oil filter was heating up and causing the transmission computer to go crazy. I also drained and filled the differential fluid and I haven't had any problems since. I hope this helps. Good luck.
Old Oct 19, 2013 | 07:59 PM
AshenCrow's Avatar
Thank you for reporting back. A lot of people fail to do this and people who try to search for an answer never find one. I had never heard of that wiring problem and I will check that while my solenoids are still in the mail. May have just saved $60!
Update: My wiring was fine and replacing the solenoid is what fixed my problem.
Liadrin
Apr 25, 2022 02:54 PM
Shoua
13
May 22, 2016 05:19 AM
AkitaDog
Sep 1, 2015 08:05 AM
Liadrin
Sep 1, 2015 06:44 AM
vanion2
Jul 29, 2015 06:17 PM
