General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Old Feb 9, 2016, 10:33 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guide
Print Wikipost
LED turn signals
Old Jul 20, 2015 | 07:20 PM
Shoua's Avatar
LED turn signals
How did you guys get your turn signals to flash normally after replacing the regular bulbs with LEDs? I replaced my rear ones with LED bulbs, and the front ones are one-piece LEDs that I cut out and spliced into the corner lamps. After the connections were made, they just let out a constant "BEEEEEP" now; they don't even flash at all.
In an issue of Toyota Owners mag, they cut out a resistor in the flasher relay itself. The problem is I don't have that same relay, so I have no idea what to do next. I don't have turn signals at the moment.
Help?
Old Jul 20, 2015 | 11:33 PM
wyoming9's Avatar
Red face
I have only used the LED lights never the bulbs
I have the 2000 Tacoma
I replaced my stock Flasher with Napa Part # EP-35L
Not sure if that will work for what year your dealing with.
The LED lights are such a low load you need to add more resistance to the circuit.
I only had the hyper flashing never the squeal .
Maybe you have another problem.
With these LED lights the polarity is important when they are wired.
Old Jul 24, 2015 | 08:33 AM
thzpcs's Avatar
They have to have resistors, or else they will not flash properly. If the polarity is incorrect, they just won't turn on.
Old Jul 24, 2015 | 10:27 AM
irab88's Avatar
use one of these, and you won't have to add resistors:
https://www.google.com/search?q=vari...utf-8&oe=utf-8
"variable load flashers" are meant to be added to trucks that tow, where the resistance of the flashing lights varies every time it tows a trailer.
Old Jul 24, 2015 | 12:41 PM
wyoming9's Avatar
Red face
Those flashers just are adding more resistance to the circuit .
some people would rather spend the time adding resisters to the circuit I would rather just change a flasher.
I am not sure that is just working smart or being lazy.
Old Jul 24, 2015 | 11:10 PM
Shoua's Avatar
Thanks, guys.
I actually ordered the flasher with the one Wyoming9 used. It worked out fine, other than having to extend the wires, as it was not a plug-in unit (I already expected that). It cost me $17.
I definitely did not want to add resistors.
Old Jul 24, 2015 | 11:24 PM
wyoming9's Avatar
Red face
Interesting in my application it was plug in.
I am glad it worked in any case.
Old Jul 25, 2015 | 08:37 AM
RAD4Runner's Avatar
I am with Wyoming.
Adding a resistor after you replaced your bulbs with more efficient LED's is counterproductive. Adding the resistor in parallel would increase the current load back to old level.
Getting an electronic flasher relay that would work with the new LED's is the way to go.
Old Jul 26, 2015 | 03:07 PM
Shoua's Avatar
It could be because my truck is an '89 'Runner.
I forgot to mention it in my original post.
Old Jul 26, 2015 | 10:59 PM
dropzone's Avatar
Fossilized
Originally Posted by Shoua
Thanks, guys.
I would grab another to have around, mine failed after about 3 years, popped the new one in with the deputy there, no ticket
I found them at auto zone
I also had to extend the connections
Old Jul 30, 2015 | 08:51 PM
Shoua's Avatar
That's a good idea, dropzone.
Old May 21, 2016 | 01:18 PM
paynemw's Avatar
Hmm... I modified my stock flasher relay and I added the converter box for a 4 wire trailer connection and my "running light" or brake light also flash when the turn signal flashes. I wonder if i throw one of these variable load flasher relays in it will fix my problem. Thanks.
Old May 22, 2016 | 12:35 AM
wyoming9's Avatar
you have something wired wrong or a bad ground causing the brake lights to flash
Old May 22, 2016 | 05:19 AM
paynemw's Avatar
So.... I thought so too. I double checked everything. Its only a slight flash (not as significant as a turn signal flash). So my pops busted out the multimeter and we checked every wire, we bought a new converter, wired it again and I piggy backed onto another ground to ensure I had good ground.
It's weird because there is no issue when I have an incandescent bulb in...
ghostmoney
Jan 28, 2018 11:42 AM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
moonpie
Jul 31, 2015 11:58 PM
PopsDad1
Jul 30, 2015 02:21 PM
