- suspension options
- New Yota Owner, Need Help Figuring out a miss
- Intake plenum pic
- Carbs
- temp guage spike?
- Locking glove box for 86 4runner???
- ANYBODY else running a buick 3800 V6? need cooling advice
- An open letter to the damn toyota guy who..
- Hiding the gas tank on 89 runner
- 87 runner blown head gasket?
- Should I buy this truck 1994 V6 3.0...
- Look what I broke.....
- gas tank repair?
- Mishap leads to new suspension set up
- Help with audio for 94 Ex Cab pickup
- Went wheelin'... now the truck won't start
- Mounting AUX gaunges
- demello rock crusher sliders question
- 90 Pickup
- How much to rebuild tranny/tcase?
- im lost about what to buy
- Bad Compression = Engine Vibration at Idle?
- ifs rear truss ?
- Low loping idle and a lot louder
- rear wheel well positioning.
- Need help Just bought 86 4runner
- My starting problem is getting really annoying. HELP!
- Cool & Cheap 4runner Storage
- Weakest link in stock 94 Runner
- Really Pissed!
- HELP ME! 7.5" vs 8" rear diff. ...????
- 1986 Blown Head Gasket, now what to ask for it?!
- How can I make my 95 4Runner lose weight?
- Quick question on gas vents...
- Pics of bedlined rocker panels?
- 95 4runner suspension options
- Shift seat bushing installation
- tires
- 88 SR5 Power Door Lock Control Relay LOCATION?
- thwup thwup thwup... what's wrong?
- Went wheeling this weekend!
- New Toy...set up comments please
- 4runner
- suspension and things help plz?
- Anyone ever use a camo wrap?
- Audiovox ROSTRA Alarm Fob...
- 3vze timing marks, should i be concerned
- A-Arm broke in half, what are my options???
- a/c kit
- Bigger CV axles?
- New Trail Rig Build (86 Xtra Cab Flatbed) Lots of Pics!
- 4.875 gears in a V6 Auto?
- Port and polish??
- 94 runner headgasket;fix or swap
- Crazy Craigslist Prices!!
- susp. setup question
- New to me 1987 4runner turbo!!!
- Buying 1st toyota
- Does this sound like a good deal?
- Finally pics and a Question
- which toyota thirds will fit my 88 runner
- will a taco transfer case fit in a 91 pickup?
- Good by rear sag
- First time problem on 22R
- 3VZE valve cover torque?
- UnPlugging the O2
- 22re V6 3vze automatic tranny
- Whoa No Brakes!
- When it rains it pours!!
- Casualties of my clutch install
- locking hubs
- 224
- pinhole leak/crack in top of radiator
- HELP 1986 22r engine trouble
- Cluck noise..pretty loud!
- bobbed 88 x-cab
- front diff mounts
- front diff mounts
- Rusted O2 sensor bolts... whew
- My truck got broken into..what year glass will fit
- 2nd 3.0 head gasket update
- egr plumbing problem
- Rancho IFS setup
- Possibly need a new engine!
- Convert ebrake lever to a 3rd gen 4runner style?
- e brake
- suspension clicking in front!!!!!!!!!!
- Second Blown HG on 3VZE: Desperate
- 3vze pull and seperation problems
- IFS Lift Questions
- Installed MC Rear Bumper Tonight
- New upgraded brakes!
- look what i found on craigslist
- using a hushpower 2 rez with a magnaflow muff
- Rear Anti Lock
- weird engine sounds...help
- How many cores in an OE radiator for a 1994 Pickup?
- NEW ,LIFT,RIMS,TIRES,and more,for a new STYLE.tell me what you think!
- light problems!
- Brake help ASAP!!!
- They had to cut down my spare.
- anyone running ted's stick?
- Marlin Crawler Shifter Seat
- Grille Guard Fitment... (Also for sale)
- my custom IFS truss
- No Luck Tshooting no 4X4
- Corvette 1... Sunfire 0... 4runner... 0
- 91 4runner Power windows wont work
- parts supplyer ?
- Stereos and your trucks...
- Post '03 Cummins goes DOWN!!
- subaru 1 yota 0
- hot e-bay deal
- Bad sound in 4wd....HUBS?
- arb snorkel install template/instructions
- Opinions On This 91 4Runner
- Tricks for tapping in the front cam seals?
- '89 2wd Pickup - Drivers glass replacement
- R150 Tranny rebuild kit need advice
- stock wheels off a '94 2wd pickup.
- Is there a difference between 2wd and 4wd corner lenses?
- Idler Pulley Bracket Question?!?!?! (using heads from a 90 on a 93)
- lift kit
- Replacing Fusible Link
- reg cab excab swap?
- Symptoms of bad rear springs?
- Rear spring recommendations
- Pics
- Help ID injector parts - getting the dealer runaround
- My toyota's
- Tire Selection for mud!
- Tire Selection...
- pickup vibration problem
- replacing quarter glass in a 1st gen 4runner
- terrible noise in 4wheel drive
- Replace box/bed 86 xtracab shortbox !
- Cruise control needed
- 3.4 swap wanted!
- Help of all sorts...
- RPM vs Boost - turbo sizing
- V6 sensor id help please
- Larger fuel capacity
- ticking nosie
- sisde decals
- Lift, suspension rebuild
- 3.0 v6 question
- My truck has GOUT....running REAL rich..help me out
- Using a chain strap to get cranshaft bolt off
- ISR mod supplies questions
- front end problem
- gear help
- Please Help!!!
- 1993 Suspension questions
- CD Changer in the Gen1 4Runner center console
- Strange Engine Behavior
- 88 4Runner question
- Is there an easy way to pull the motor??
- New Engine, Glazed Rings
- My Latest Project - Cheep Wheels
- Calling all cooling system gurus
- car won't start?
- 2nd gen 4runner cargo dividers/sleeping platform
- WTB list
- 22re Headman Header
- Is this what your 22re sounds like?
- First Trip After Rebuild & OME
- 92 3vze jumping time
- new muffler not loud enough
- testing fan
- Window problem on a '94 Runner
- Access Spark Plug Wire Help!
- broken bolt and extractor
- FJ80 coils vs. 2nd Gen stock coils
- Got my 35s!!
- 1995 4Runner Lamp for Headlight Replacement.
- A new mod on my yota
- toyota trailer wiring
- Why do i love toyota(proven further)?
- tire cover
- 88 4runner gears
- please help... another 3.0 disaster
- Check Engine Light Info Please
- pic/article of ironman stewart's 4runner?
- 2nd gen trimming front valance pic request
- Headman Header
- need parts
- 92 3.0 Stalls when headlights turned on at operating temp?
- Compression test question
- 3rd gen pickup seat covers?
- Patching Rust
- are my valves bent because my T.C. broke
- Bad igniter
- Regearing questions
- Almost there...CEL 24 gone...New CEL 25 with details...
- Scored a yota model kit
- torque spec 22re
- Getting ready to do head gasket/timing chain 22R
- How do you remove a tapered washer?
- timing belt noise
- new truck. ^_^
- ok all you gearheads...
- transmission dipstick?
- New remanufactured 3vze engine, Running Rough. *tear*
- Fuel injector cleaning?
- new motor, weird studder
- "Stinger" bumpers
- 87 4runner leaking oil
- Why do I have less power when I turn on the A/C?
- T-case troubles
- 4runner questions help!!!
- 88 runner
- Debating Model and Engine...
- cam help
- Where can I get a decal like this ???
- Funny mistake
- pinion play?
- 3.0 to 22re
- ABS/Brake Light help
- ISR alternative?
- two little MAF screws make neat tearing sound
- 4x4 Automatic will not shift in 2 HIGH or 4 HIGH.
- front driveline question
- custom intake help
- 3vze-which job is harder: HG repl or rear main seal?
- plastic shifter plate....?
- "Adventure" Truck Color?
- my ARB BUMP.
- Double Din Stereo In 95 Runner
- '94 SR5 V6 Auto 4runner Q's
- New LC Engineering 3VZE Header
- Truck Shop Recommendations Oregon Area
- 88 4runner Pics
- 3vze rough,missing, crappy, just rebuilt -AT WITS END. PLZ HLP
- 88 yota timing chain
- Help please! Transmission leaking!
- Someone Locked My Hubs...
- beef up A340H tranny???
- Cab/bed stock bolt length
- O2 sensor from sparkplugs.com
- how do you keep your shop organized
- help with valve ID?
- IFS lift vs SAS
- My carb needs a rebuild..
- Looking to buy a 1989 Pickup
- Gearing Help Again Please
- Need advise
- Will this diff fit my 4Runner?
- Dual case or SAS
- rough idle, Seafoam?
- AC Trouble
