Help please! Transmission leaking!
Old Aug 23, 2007 | 06:24 PM
mYnAmEiSmUd's Avatar
Hi. I recently changed my clutch about the beginning of summer.
I got under my truck today and noticed that i am leaking transmission fluid from the rear of my transfer case. Right where the rear drive line hooks up to it.
I am wondering if there is a seal there that i may have destroyed during disassembly or reassembly. The only other thing that i can think of is that i put to much gear oil in there and its spitting it out the only way it can. If i remember right i put in about 3 quarts. The amount listed in an 86 factory repair manual.
Any advice or tips are greatly appreciated!!!
Thank you!
-matt
Old Aug 24, 2007 | 02:16 AM
TORTIS's Avatar
did you drop the transfer case? the seal may be wore out. if i remember right. pull flange and the seal is right behind the flange. are you sure it is not coming from the transfer case shifter?
chuckross1957
Jun 28, 2019 10:19 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
yourrealdad
Jul 29, 2015 11:08 AM
HookahRoo
Jul 20, 2015 07:06 PM
jjrbus
Jul 17, 2015 07:06 AM
